2nd time here we go again clanking ticking noise after engine shut down
#81
as good for flat tappets anymore. They where the lsst holdout when the formulations had to change.
The OP has flat tappet lifters and oe stamped steel rockers.
I’m willing to bet these motors have an okling issue. Galley plug, cam bearing clocking? or ???
#83
Did someone mention oil galley plugs. I know that all the magnum engines that Mercury puts out there are 2 small tiny holes drilled in the oil galley plugs which is located on the front of the block on top of the cam shift behind the top timing gear. These plugs are to reinsure oil getting back to the oil Pan fast as the boat goes up-and-down over waves. This is what a Tech Support mercruiser service rep told me years ago. They don't want to wait for the oil to come down from the head they want to make sure it returns to the oil pan as fast as possible.
#87
Roller rockers will fit under the stock Merc valve covers used on Gen V and IV engines. You just need to grind off the drip tabs which is what Merc does this on the blue engines. Not sure it will work on your Mark IV valve covers
#90
and that was at idle for a few seconds. Either way that oil is getting back to that pan fast. Whatever you say it does, air bleeds for lifter galley, lubrication for timing gear chain, etc a mercruiser high performance tech person told me they want the oil back in the pan. period...his words
