2nd time here we go again clanking ticking noise after engine shut down >
Old 09-05-2021 | 03:27 PM
It sounds like my CMI headers after idle time ,water drains out tailpipe at idle doesn't have enough water volume to fill headers to top of the rise .bump up idle a touch to increase water volume mine goes away .on certain days depending on humidity I can see the condensation line on outside of header
Ironhorse dave is offline
Old 09-05-2021 | 05:06 PM
35fountain's Avatar
my engine is off
35fountain is offline
Old 09-05-2021 | 09:14 PM
Sounds like dieseling. Self combustion of fuel after shutdown. Not good for the engine.
Idle set too high, carbon build up, are a couple of most common reasons. If engine is warmed up it could be do to overheating.
justfishing is offline
Old 09-06-2021 | 09:24 AM
35fountain's Avatar
I am going to pull off a valve cover start it up for a minute or so take a video of anything moving after shutdown... to be continued...........
Old 09-06-2021 | 10:13 AM
Rookie's Avatar
Sounds like springs and keepers snapping back in place. Very strange.
Rookie is offline
Old 09-06-2021 | 01:20 PM
35fountain's Avatar
Happy Labor Day everyone! Check this out......... I cannot believe this!
Old 09-06-2021 | 01:32 PM
Veteran: Army
So it's got to be related to hydraulic lifters or valvesprings - those are the only non-solid objects in the valvetrain that could potentially move after the crankshaft and camshaft have stopped rotating. My money is on the lifters somehow incrementally bleeding down. But that's just my uneducated guess.
DrFeelgood is offline
Old 09-06-2021 | 01:45 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Were the balls in those rockers kept paired up or were they mixed? Seen this before and that was the problem believe it or not.
the deep is offline
Old 09-06-2021 | 01:51 PM
35fountain's Avatar
yes. they were a brand new set I installed. I removed the ones with the roller tip from Compcams. They weren't getting lubricated.. Can't use them with a high volume oil pump.
I ordered a set of compcam lifters and stock rockers
Old 09-06-2021 | 02:00 PM
F-2 Speedy's Avatar
did you measure the plunger depth to roller tip from old filters to the new ones ? that one spring looked like it was close to coil bind
F-2 Speedy is online now
