2nd time here we go again clanking ticking noise after engine shut down >
Old 09-07-2021 | 07:38 AM
  #41
Before you take that engine apart I would do a leak down and figure out which cylinder is dead. Might as well fix that while you’ve got it apart of course I’m sure if you take the engine completely apart you will find out what is wrong but if you were just going to dig into the lifter valley you might want to see which head needs to come off to figure out why the cylinder is low.
Bill Glueck is offline
Old 09-07-2021 | 07:47 AM
  #42
35fountain's Avatar
Originally Posted by SB
Why did you rebuild the carbs ?
Reason for asking, I was asked to listen to a boat the other month that was making knocking. Oh yeh it was ! Con rod for sure. Noticed person was having hard time jeeping engine running. Took a look and a needle and seat was not closing. Drained the engine oil and boy was it thin. Changed oil, fixed carb, and wallah….no more noise and engine ran smooth. Couldn’t believe the loud con rod noise totally went away.
Ethenol loves carbs..port engine wouldn't even idle...Took carbs apart.. soaked them in chem dip..Carb cleaner in metering blocks, blew out with air..changed all parts.. good as new.. idles and runs great.
I was told to drain the fuel bowls after winterizing.. I forgot last year lol
35fountain is offline
Old 09-07-2021 | 07:56 AM
  #43
35fountain's Avatar
No cylinder is dead....?? where did this come from? last week
Old 09-07-2021 | 08:05 AM
  #44
SB
Thinking s different thread. I have done this s few tines too. Doh !
So, back to my last post. The carb issues diluted the oil. Change of oil got rid of noises. In your case, you said oil additive made noises a little louder ? Boat has not left dock in 2 years ? Been started and ran a bunch ? So, before tearing things apart maybe do oil change first ? Never heard lifters do this even with ratty oil, but, never heard them do it……lilolololol Anyway, should be done anyway, so……
round table talk….throwing things out there
SB is online now
Old 09-07-2021 | 08:16 AM
  #45
F-2 Speedy's Avatar
agree see post #18
F-2 Speedy is offline
  #46
35fountain's Avatar
but what if the pushrods are galled and less oil is getting on top ? the rockers and balls could be worn again...
taking the zrod amsoil 20-50w out. putting in valvoline zr1 racing 20 50 reg oil for a test
Old 09-07-2021 | 08:39 AM
  #47
SB
Btw, your previous rockers…..Typical for those comp roller tip rockers to burn up. Seen it first hand dozen times ???? After all these years i can’t believe they still sell those piece of ****s. And, btw, on sbc, bbc, stock oil pumps, high volume, ….doesn’t matter….they suck. They over heat, smoke sometimes, turn blue..,,,horrible.
So….don’t let yourself think / include that experience for what may be happening now.
SB is online now
Old 09-07-2021 | 08:42 AM
  #48
Originally Posted by 35fountain
No cylinder is dead....?? where did this come from? last week https://youtu.be/deTgvAvm3M8
I’m going by what I hear on your clip turning the engine over. I hear an audible Low cylinder. Just figure if you’re going to take that motor apart you might as well see what it is. Could be a valve could be a gasket could be something to do with the piston and/or cylinder. But need to figure it out.
Old 09-07-2021 | 09:33 AM
  #49
35fountain's Avatar
ok thanks for your input. but both motors are doing it and they run great ?
I am going to check for galling of the pushrods and rocker balls. I am also going to check the geometry. I will check the valve stem mark to make sure the rocker is riding at the center of the stem. If they are galled I may not be getting oil at the rocker at the right time.
Old 09-07-2021 | 09:38 AM
  #50
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Could the popping still be in the headers/exhaust, and you are feeling it through the exhaust valves/rockers only?
Sydwayz is offline
