Mighta made an oopsie.  Name that Knock! >
Old 08-11-2022 | 02:32 PM
Veteran: Army
#5 Exhaust rocker off the valve
#5 Exhaust pushrod bent
#5 guide plate broken
SB gets the golden ear trophy
Pics coming momentarily
DrFeelgood is offline
Old 08-11-2022 | 02:34 PM
Veteran: Army
Old 08-11-2022 | 02:35 PM
Veteran: Army
Originally Posted by liberator221
Was 5 one that had high leakage?
Something dancing around in there.
Bore scope?
Nope. That was #7. #5 had only 5% leakage.
Old 08-11-2022 | 03:02 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Yep.
the deep is offline
Old 08-11-2022 | 03:16 PM
the deep's Avatar
Fast Singles Club
The top of that valve took a hard hit and now may be bent and hung open as well.
the deep is offline
Old 08-11-2022 | 03:19 PM
F-2 Speedy's Avatar
that doesn't explain what killed the plug, there's some debris loose in that hole,
F-2 Speedy is offline
Old 08-11-2022 | 03:31 PM
the deep's Avatar
Fast Singles Club
That's what she said.
Joking aside, a piece of ring land maybe.
the deep is offline
Old 08-11-2022 | 03:42 PM
Veteran: Army
I just borrowed a cheap usb borescope from a buddy, didn't really see much. saw some clean areas of the piston at the outer periphery, possibly consistent with the rich burn that was occurring.
I guess my big question at this point: Was this a coincidence, happening right as I began to feed a tiny amount of water in the intake, or did I cause this? And if I caused it, how?
Old 08-11-2022 | 03:48 PM
the deep's Avatar
Fast Singles Club
Leaky header syndrome is possible......water don't compress. Pressure check your header with attention to that cylinder to be sure.
Add: Looking at your pics I see a clean area in that pipe that appears to be a water leak although looking at a distant pic makes it difficult.
the deep is offline
Old 08-11-2022 | 03:53 PM
Veteran: Army
There is a small amount of rust in the exhaust ports of cyls 5 and 7 in that header. Not a lot, but there is some. There also was a little bit of water in the bottom of the V-band clamp at the header-tailpipe junction.
