-   -   Oil temp/cooler setup questions (https://www.offshoreonly.com/forums/general-q/377210-oil-temp-cooler-setup-questions.html)
BBYSTWY 09-26-2022 09:29 AM
I will try to look him up thanks!
Another option, back to the oil pan, I have several buddies that are welders by trade...would it serve the same purpose if I modified my current pan to a tee style bottom like the ones they sell instead of buying one? Could just add onto my current pan and add a little on the pickup tube and have my extra capacity unless there is some kind of magic inside of those things I'm not aware of??
GLENAMY 242SS 09-26-2022 09:39 AM
Magic? Baffling and oil trap around pickup. Also the pickup height adjustment is critical, call Ron he is an expert.
BBYSTWY 09-26-2022 09:53 AM
Copy that thanks!
GLENAMY 242SS 09-26-2022 10:11 AM
Ron Sporl Performance Marine 504-616-6005
Tell him Gary and Vienna say Hello
BBYSTWY 09-26-2022 10:15 AM
Perfect thanks!!
BBYSTWY 09-26-2022 12:54 PM
13 Plate Remote Cooler Assembly - Hardin Marine (hardin-marine.com)
Hardin Marine - HP Engine Oil Cooler 3" Diameter, 25" Overall Length, 1" NPT Connection (hardin-marine.com)
Looking at these two options for a cooler. I can't mount either above the bell housing due to interference with my exhaust so I will have to make some mounts or figure out a way to mount them elsewhere....what's everyones thoughts on these 2 options? Square or Round basically hahaha
GLENAMY 242SS 09-26-2022 02:33 PM
I went with the smaller square. Easier to mount from a real estate perspective and you can change the internal element if needed. Very easy to plumb.
I don't make near your HP so smaller works great for my application.
BBYSTWY 09-26-2022 02:35 PM
Good point with the real estate perspective...haven't had a chance to call Ron yet but maybe he can answer that question too
GLENAMY 242SS 09-26-2022 02:39 PM
I've seen the square ones on some of his blower builds, I don't know what size, that's the experts call.
BBYSTWY 09-26-2022 02:51 PM
lol fair enough
