Mounting power steering pump. >
Old 03-18-2023 | 12:08 PM
Veteran: Army
Originally Posted by Peter Oberg84
why does some have 2 pumps? I only have one on starboard engine that serves both drives.
It's for redundancy if you lose your Stbd motor and have to come in on Port only.
DrFeelgood is offline
Old 03-20-2023 | 01:02 PM
Dan, Jones is big in circle track world.
https://www.jonesracingproducts.com/
They offer these, most around $100ish or less with a quick Google.
Maybe you could get one of these to suit your situation.
cheech is offline
Old 03-20-2023 | 01:08 PM
BBYSTWY's Avatar
Shoulda switched over to serpentine belts and you could run stock 500 efi stuff
BBYSTWY is offline
Old 03-20-2023 | 01:23 PM
Originally Posted by ICDEDPPL
my pump is on the drivers side ....
this would do it but not available https://www.summitracing.com/parts/jrp-psh-8001-bb
Glared over this.
Call these guys or Speedway motors maybe.
Behrents website doesn't say in stock or not.
https://behrents.com/
cheech is offline
Old 03-20-2023 | 07:24 PM
Originally Posted by cheech
Glared over this.
That`s funny , I found all the same stuff.
I actually have a real paper Jones catalog ! wo hoo
ICDEDPPL is offline
Old 03-22-2023 | 12:13 PM
Originally Posted by underpsi68
A lot of people are using factory car pumps. You just need a controller to make sure they put out the right pressure. There is a company that sells the controllers now.
I remember a while back someone mentioned this (for GM Saginaw pumps) and the only mod needed was to increase the output fitting orifice size to provide adequate flow at lower RPM's (idle). Just need the right size drill bit.
zz28zz is offline
Old 03-23-2023 | 11:41 AM
electric steering pump. does away with all of it.
JIMG is offline
