We hurt the 496.... >
We hurt the 496....
We hurt the 496....
Old 10-28-2024 | 07:32 PM
  #201
Rookie's Avatar
I can brick a GM ECU for not pulling the radio fuse when writing a tune back or not having a charger on it.
Carry on...
Rookie is offline
Old 10-29-2024 | 05:13 AM
  #202
SB
Carry on...
What does that mean ? Turn it into a useless brick ?
SB is offline
Old 10-29-2024 | 09:18 AM
  #203
Dan,
I just can’t see how the ECM would care where it’s getting its 12v from….
Thanks. Brad.
You`re really fighting this instruction hard ! lol
It doesnt but if there is a spike the battery will absorb it.. interference is also issue , going straight to battery helps with that too.
SB , yes . as good as a brick.
ICDEDPPL is offline
Old 10-29-2024 | 09:26 AM
  #204
Dan,
Nope. Not anymore. I don't have to agree with the logic to follow it out of an abundance of caution. I'm going straight to the battery and making provisions to charge both batteries simultaneously.
Thanks. Brad.
Brad Christy is offline
Old 10-29-2024 | 10:18 AM
  #205
Guys,
I picked up one of these, and I intend to wire it like this:
This still leaves the ECM out to dry in the event of a catastrophic ECM battery failure, but it's the best I can come up with, and no different than a single battery setup. On the right track?
Thanks. Brad.
jsaduwffebhuvve
Wildman_grafix is offline
Old 10-29-2024 | 10:37 AM
  #206
jsaduwffebhuvve
Wildman,
Covfefe...?
Thanks. Brad.
Old 10-29-2024 | 01:21 PM
  #207
Wildman,
Covfefe...?
Thanks. Brad.
No went to asked something and figured it out. Not able to delete comments.
Old 10-29-2024 | 03:38 PM
  #208
Connecting directly to the battery cable wiring, you remove the potential for lower voltage feeds from poor connections (resistive) down system. Also noise as Dan mentioned. Ground wiring also important for electrical 'noise'.
The protocal is likely to ensure positive successful use and removes a factor when troubleshooting. You may have good wiring practice...others...as we've all seen, are less than desirable.
Tartilla is offline
Old 10-29-2024 | 05:18 PM
  #209
I vote to wire straight to the battery.
sutphen 30 is offline
Old 10-29-2024 | 05:24 PM
  #210
Guys,
Thanks. Brad.
Tartilla,
Yup. As you can see from the diagram, I am planning to connect straight to the battery, including the ground. I just had to figure out how to charge both batteries, regardless of which battery the switch was on. Now, if I could just find an automatic, voltage sensing switch that would instantly switch to the other battery and give me a chance to get back to the trailer should the direct-connect battery take a dump. As it is right now, if the battery the ECM is connected to takes a sh!t, I'm high and dry, and I'll NEVER hear the end of it from the CFO.
Thanks. Brad.
