We hurt the 496....
#221
Why make this so difficult? I have ran every boat that I have had with the battery switch in the "both" position and I have never had to be towed in because of dead batteries. I understand that a shorted battery could cause issues with doing this but the chances are small. You are way more likely to be towed in for a broken drive, overheat condition or some other mechanical failure.
Why have the switch, then? By the time you discover a dead battery, they're both dead. I have been told by literally everybody with even the slightest opinion on the matter that you NEVER put the switch on both unless both batteries are too soft to drive the starter, and you're HOPING that the two of them combined will get you started, then you immediately switch to whichever battery you think is weaker to charge it.
Just because something else might get you first, doesn't mean you don't mitigate the risk of a relatively easily avoidable problem.
Thanks. Brad.
#222
Wildman,
No. The two lugs of the ACR are connected to the two battery lugs of the switch and actually disconnects, disengaging the parallel circuit, while discharging (starting or running the stereo while anchored, etc.), so the starting load only goes through the center lug of the switch.
The only thing that makes sense is a scenario where one battery has been significantly depleted and draws heavily on the other battery during charging, when the parallel connection of the ACR is engaged. Outside of that, I can't see the benefit of 4ga wire when it's only a 10ga coming off the alternator. Thoughts?
Thanks. Brad.
Thanks. Brad.
#223
#225
Maybe. But we've been running this boat in the mid- to high 70, and the boat has yet to even hint at a desire to get out of shape. I am very careful when I run it hard. If the boat had been a handful beforehand, I'd have a different approach. If I find that it seems to have learned a new trick as we surpass prior-to WOT speeds, I'll stay out of it until the steering can be properly addressed. I fully understand the implications.
That said.... Business has been slow this whole time since we had the piston failure. This has been a good thing for getting things done, but bad for paying for the effort. The steering is still on my radar, and may yet happen before spring. But, for the moment, it's a want, not a need, as far as the checkbook is concerned. I am working out issues that don't hit like a truck in the budget area in the meantime.
Thanks. Brad.
#226
The chances of one battery taking out the other is close to 0 .. well in my case over the last 15 years anyway .
That`s the last thing I ever worried about .. the relay is a good idea thou either way
Edit: I would run a negative cable from one engine to the other also .
#227
generally you do not run on both if you have twin engines as the two alternators can fight each other and cause issues. on a single engine with two batteries running on both is fine. if you have a concern that one battery is low you can start on the other and switch it to both and it will be fine.
#228
with 1985 wires it would take 2 batteries to start a single engine in the cig. Lots of time I`d leave it on ALL most of the time. Same thing in the baja .. easy to start but I liked having both batterries while starting ... anyway that has never ever left me stranded either.
I’m going to call BlueSea and make a suggestion for a new product. I doubt it will get us anywhere, but a phone call is free, and they are probably the only people that would be interested in developing such a product.
In the meantime, I am working on finalizing the electrical in the engine well with the best configuration the market has to offer.
Thanks. Brad.
#229
Guys,
On other fronts…. Heads are done. Block is done at the machine shop. Cam is on order. Mods to intake manifold is all but complete. Fuel and oil line fittings and hose are in. Moving forward.
Interestingly, the builder happens to mention that there were no valve seals on the valve stems when he disassembled the heads. And we weren’t burning any perceivable amount of oil. We were losing a bit over time, but I attributed that to the PCV being part of the intake manifold, and the ProCharger pushing oil out the dipstick. Weird, right?
Thanks. Brad.
Thanks. Brad.
