We hurt the 496.... >
We hurt the 496....
We hurt the 496....
Old 01-27-2025 | 04:04 PM
  #441
Originally Posted by 87MirageIntruder
The only time I've blistered the inside of the rubber exhaust hose is when I had a seawater pump/flow issue.
87Mirage,
I can’t tell you if this segment was between the elbow and the diverter or between the diverter and the tip, or whether it was on the upstream or downstream end, but I do remember seeing it on the port side only, which we all know runs a bit warmer than the starboard. I think I’ve since pitched it, but it seems like I had another segment with even more obvious extrusion of nylon on the end of the hose.
With what we found with the rubber seal disks on the ends of the heat exchanger, and the increasingly warmer running temps prior to the piston failure, a shortage of flow may have been the culprit. I do know the seawater impeller was is near perfect shape when I recently replaced it, so that wasn’t it.
Thanks. Brad.
Brad Christy is offline
Old 01-27-2025 | 04:10 PM
  #442
Swollen heat exchanger end gaskets cause them to run hot so that is a good theory.
87MirageIntruder is offline
Old 01-27-2025 | 04:13 PM
  #443
87Mirage,
Is this what you’d call “swollen”?
I didn’t even know these were a thing prior to the disassembly of the heat exchanger. I’ll be having a look at these every spring from here on out.
Thanks. Brad.
Old 01-28-2025 | 07:41 AM
  #444
Guys,
While we're on the subject, what's y'all's recommendations for exhaust hose? I see lots of options.
Thanks. Brad.
Old 01-28-2025 | 07:53 AM
  #445
Amazon.com: LANKEQI ID 4 inch Straight Silicone Hose Coupler 8 inch Length 4-Ply Reinforced with Stainless Steel T-clamps (ID 4") : Automotive Amazon.com: LANKEQI ID 4 inch Straight Silicone Hose Coupler 8 inch Length 4-Ply Reinforced with Stainless Steel T-clamps (ID 4") : Automotive
These work fine
snapmorgan is offline
Old 01-28-2025 | 10:18 AM
  #446
87Mirage,
Thanks. Brad.
That actually isn't that bad... Thats pretty normal for those heat exhanger rubber seals.. Not saying its good, but I've seen way worse. To be honest, I'm actually shocked nobody has come up with a more resilient solution for this yet as its so common... I wonder if you could make like a waterjet cut piece of silicone?? Might last longer?
On a side note, haven't visited your thread in a while, but I apologize for insighting a catch can riot lol..
ashipshow is offline
Old 01-28-2025 | 10:25 AM
  #447
AShipShow,
Oh, I'm sure. I'd guess a lot of people don't even realize they are a maintenance item. I didn't.
The one in the pic appears to be just a sheet of neoprene rubber, with no reinforcement. The ones I ordered and installed are nylon (I think) reinforced. I have to think they will last longer. Still gonna check them every spring. It's a pretty easy check, now that I know.
I might check with a seal and packing supplier here in Dayton and see if they've got an option that will be better than what I bought.
Thanks. Brad.
Old 01-28-2025 | 10:30 AM
  #448
For 10 bucks.. these might be worth trying.. just pop the center hole in it and run it...
Would be interesting to try one on one end and the OEM on the other end and compare after a year.
https://www.mcmaster.com/1084N14/
EDIT: Just saw youre previous post... mind letting me know where you got reinforced gaskets?
Old 01-28-2025 | 10:33 AM
  #449
AShipShow,
Kevlar reinforced. That's intriguing. I'll see what the local shop has along those lines.
​​​​​​​Thanks. Brad.
Old 01-28-2025 | 10:35 AM
  #450
AShipShow,
https://a.co/d/1A6q0Kx
Thanks. Brad.
