Subs
Old 02-13-2004 | 03:52 PM
TOMMY HIWAVE's Avatar
Default Subs
DOES ANY HAVE BOXES MADE FOR THEIR SUB-WOOFER THAT ARE UNDER THE BACK SEAT AREA? IF SO PICTURES PLEASE.
I WAS TOLD UNLESS YOU HAVE A BOX THE SUBS WILL SOUND BAD.
TOMMY HIWAVE is offline
Old 02-13-2004 | 04:04 PM
Rivercrazy
Running subs in an infinate baffle will not allow the sub to reproduce sounds as it was engineered to do. Some are actually designed for IB but do not sound as good or are as loud compared to subs with enclosures.
I have 4 10" subs mounted in the base of my back seat bench.
You just need to know what design you are going with (i.e. Sealed or Ported) and build an enclosure to the right size and withing the confines of the size of the seat pedestal.
Most 10" subs require about .65 to .75 cubic feet of airspace and 12" need about 1 - 1.25 cubic feet in sealed applications. Ported boxes require about 2X the space. Just refer to the specific recommendations of the subwoofer you choose for box recommendations.
I'd go with 3/4" marine plywood over MDX (medium density fiberboard) in a boat due to the pounding, moisture, etc....
Old 02-13-2004 | 05:55 PM
84monza
I installed my subs (2 10 jl's) down in the cabin, in a box that I incorporated in a storage area I was not using. The bass wave develops in the cabin and has a deeper tone. You will need to have you cabin door open when listening of course........
Old 02-14-2004 | 07:36 AM
Audiofn's Avatar
Charter Member #232
There are a few free air subs out there that can hold their own. Clarions and Allumapro for example. I have had very good results in a number of aplications with the Clarions.
Jon
Put your best foot forward!
Audiofn is offline
Old 02-14-2004 | 03:50 PM
audiofn do you run free air mostly
Old 02-14-2004 | 11:01 PM
Audiofn's Avatar
Charter Member #232
Sealed is prefered but also a LOT more work. You can be more sure of the outcome with a box. However I have yet to be real disapointed with free airs. I find that the expense of adding boxes can often be outweighed by adding a second pair of subs.
Jon
Audiofn is offline
cigrocket
14
12-05-2005 08:55 AM
Nordicflame
Nordic
4
06-03-2005 01:57 PM
liquid asset
Baja
23
04-13-2004 11:01 AM
ThirdBird
07-27-2003 08:41 PM
