Go Back  Offshoreonly.com > Owners Forum > Kryptonite
Kryptonite project begins.... >
Old 05-17-2010 | 08:29 PM
  #221
Originally Posted by mastercraft240
Spoken like a true boater.
How about them shirts???
Order is in....probably another week or so. They said they are having trouble finding the pink sparkles you wanted....haha
jdub is offline
Old 05-17-2010 | 09:04 PM
  #222
boat is looking really nice, good job.. Hope to see it @ the summer bash June 26th
DonRoc is offline
Old 05-17-2010 | 09:16 PM
  #223
Thanks Don. I'm still planning on coming. I haven't booked a room yet though. My accomodations needed will depend on who comes with me
jdub is offline
Old 05-17-2010 | 10:11 PM
  #224
c_deezy's Avatar
Originally Posted by jdub
Motor just about ready.....also hung the drive on
Engine compartment looks good. I like the k-plane pump location, that's about how I plan on mounting mine.
c_deezy is offline
Old 05-17-2010 | 10:58 PM
  #225
Dude, you're memory really must be going with your age!! I didn't think you were that old. Pink sparkles was for the thongs for all those college girls that your too old to gettttttttttttttttttttt
Mastercraft240 is offline
Old 05-18-2010 | 06:37 AM
  #226
We'll see....we'll see....leave your books at home because I'm going to school you!
jdub is offline
Old 05-18-2010 | 06:40 AM
  #227
Thanks but I can't take credit for the pumps. The previous owner mounted them. He made up plates and used the thru hull hydraulic steering studs to mount them. He then drilled and tapped the plates to mount the pump mounts. It's a nice set up.
jdub is offline
Old 05-24-2010 | 12:39 AM
  #228
Holden's a great mechanic. He did a great job on the rigging. He built that thing for pure speed and rough water handling. Jdub, your boat handles better in the rough than other kryptonites. That shaved pad really makes a difference.
Old 05-26-2010 | 09:59 AM
  #229
Hey John, thanks for the ride yesterday. Hopefully we can get that oil temp issue figured out. I do think that the 80psi bypass is causing the oil to bypass the cooler. The more I think about it the more that makes sense, because once the temps were up and the pressures down, we cruised around at a reasonable temp, and it didnt climb like it did initially. Once it goes through the bypass, the temps will just climb and wont stop climbing until you stop.
The motor sure ran strong though, that thing is pretty quick. I dont doubt Rudy's guess of 600hp at all.
Philm is offline
Old 05-26-2010 | 09:10 PM
  #230
Took her out again tonight with a heat gun in hand. I ran it up until the oil temp was reading 240*. It only took a few minutes for it to climb. I jumped in the engine compartment with the gun and shot the oil pan, oil filter and the oil temp sender. All read around 180*. I also shot the feed and return lines from the oil cooler and there was a 40* difference. So now I'm thinking my old sender from my motor does not match up with the new Auto-Meter gauge. I'll make some calls tomorrow and see if they can ship some out to me before the weekend.
Aside from that the GPS is not working so I'm assuming the battery is shot in the antenna. So I don't have any numbers to report. But I can say she pulls hard and handles great. Flies nice and level and lands soft. Fun as hell to drive
jdub is offline
