Out of the Mold- Im blown away!
#72
5 people half a tank of gas and a cooold day.
I talked about that in another forum.
I should have talked about it here.
That day I had a garmin Rhino 530 gps in my pocket and it recorded max speed of the day at 90.
This computes out to about 16% slippage- not great, I think If I can run a 5 blade 26 I can get a MPH or 2 more and run about 12% slippage.
Uncle Dave
#73
Thank Chris! Great shot.
Any more? (that don't have my ugly azz in em)
It must have been Snr. driving in that shot. I dont think I trimmed it up high enough to get that size tail, but it looks f-ing impressive.
Im really glad you were with us that day.
Uncle Dave
Laveycraft 2750 - 710 Ilmor
Laveycraft 20.8 Sebring 406/ITS
Uncle Dave
No i didnt take any pics other than two of the roost when my dad was driving. But ya id have to agree that we went 90 and deffinatly high 80's
Congrats on the boat and thanks for having me
#74
I need some more seat time in the rig AND tons of time to shake down the electronics package.
The furuno has the ability to split the screen between chart, bottom contour, radar, and compass/ mph - I couldn't figure out how to get the "speed" screen up so as soon as I get that part figured out Ill take some picts. It's freaking complicated and Im pretty good with marine electronics having sold them for a living, but this thing is veeery different.
I was so stoked about the boat I forgot all about the rhino in my coat, until the end of the day when I got back and saw 90- about what I figured. I think if I can get few more MPH if I play around more with a few different props, and take out 3 of the 5 passengers and go light on fuel.
Actually wildhorses you can tell a lot from from knowing rpm and prop size. Go online and look up "propeller calculator" its a pretty simple formula.
If you know the prop pitch, the rpm you can turn it, and your drive ratio (most are 1.5:1) you can estimate slippage at around 12-18% for a good V, and around 7-9% for a cat or tunnel.
I "back computed" my slip rate based on the variables I knew.
There is lots of data on this site about certain hulls slip rates with different props usually the more blades the less slip,but you need to pitch down about 2 inches going from a 4 to a 5- I'm considering buying a 6 blade, but I cant find anyone who will let me try them, and Im not dropping a grand on a prop that may not "work".
Uncle Dave
#75
Uncle Dave
Uncle Dave
Good luck and your boat looks great,
Tom
#78
Quent
Dave, you might try a Hydromotive Quad 4 plus. I tried the prop on my 24 with the same engine that you have and it was 3 mph faster than a super labbed ( BBlades) 28 B1. No knock on Bret. He is the best. The interesting thing is that the Hydromotive prop was faster out of the box and was about $550.
The 5 blade thing is very hard on outdrives.
Life is good. Live well.
Quent
Quent
#80
Thanks for the compliments.
Id love to take all or even most the credit, but I really cant.
I came up with a lot of ideas but I lifted the paint scheme from Quent. I did source a long list of parts- and of course I came up with a lot of money.
The team at Laveycraft had to work hard to keep me from damaging my own project. I had 100% control, bu the project worked better when I let them loose and left it in their hands.
In terms of a client vendor relationship- it worked very well.
Originally this boat was going to be all white with a "splash of color".- imagine.
There were a lot of calls you cant see as well, like the liner is an Ultrasuede with padding between the liner and the hull so its soft to the touch and a head bump inside wont result in a bruise.
Other things were handled I never thought of like adding another set of cleats toward the front- easy right? Not quite this caused a domino effect of work that needed to be done, because the cleat when open can allow water to splash in and the guys had to make a custom molded "cup" to catch any water and them a line had to be added to allow them to drain to the back of the liner.
Originally I wanted buckets in back- but then you end up with a 5 person boat max. The guys decided to make the seat "pattern" mimic the look of buckets but kept a bench so I can fit 4 across easily and don't lose my flexibility.
Given Ill live with this for at least 15 years-(like my last Laveycraft) I could not be more pleased.
Now I have to start using it!
Uncle Dave
Uncle Dave
