Northern NJ spots
#2102
Originally Posted by sakoutis3
At least its running. Thats more than it was doing yesterday.
Doesn't surprise me at all, with the computers on the motors even bad plug wires will make the engine act funny. All that high voltage bouncing off everything get the processors all screwed up.
#2103
Originally Posted by mr_velocity
No vacuum and compression check? Sounds like they didn't have a clue and pulled out the old shot gun.
#2104
When I said replaced everything I meant everything. I've never seen these parts go bad inless than one season. No way. Its making me think OL didn't do the work I paid em for.
Replace the plug wires while your at it, just in case. I've seen bad wires make ignition coils go bad etc. Even salt on a cracked wire will do wonders. I've also seen oil leaks from valve covers make the ignition wires arc out and cross fire.
Dude, the motors have hours on it. Believe me, Billy used that boat religously... It may just be that time where you're going to start chasing stuff down. I remember them rebuilding a blower once.. It's still and can be a good running boat, not trying to scare ya just informing ya.
#2106
Originally Posted by hunster
Saw it in the water with the hatch up. Walked over and saw the cap cracked from the dock. After he replaced it the port motor ran much better.
#2107
Thats nice but it was the starboard one that didn't work.
#2108
Originally Posted by Panther
Nah, You may just have had other voltage problems that were making the other sensors go bad or haywire..
I'll say it again everything was changed. But I didn't hear they found a cracked cap. That would definatly make it not start.
And I have seen them crack for no reason exept bad part.
#2109
did it look like this? This one didn't live long enough to run on the boat
