Fukn a what do I do for steering
it is the older style. wonder if outside housing of early XRs have the same dimensions as regular old Bravo 2004 and earlier. If it would fit I have custom made top plate SS but not polished. I have plate, spacers, but you would need 6 longer SS studs/wash/nylock nuts. Also would need bolt or stud to mount rams to plate, but could probably use your old ones w/spacers, etc. I can get you a pic later if interested.
sorry my bad guys. Mike I thought you had Neils old mayfair/marine machine stuff...you have newer hardin/mayfair rams. I'll try to give you a call later tonight and get a pic up. the plate looks old school and that's what i was after for an old project. I'd polish it and it would look unique if it works. can have for next to nothing or you can try if you want to see if works...I'll just call ya later.
But what do Im know? I ran my tabs backwards, as you know
I've done a lot of research on the tabs being mounted horizontal and I think it's better in my application. But, what I haven't been able to determine is the height.
I have had great success with the tabs at about 18 to 20 deg. I think that when they are at horizontal and the hull is landing a little right or left then the tab actually will contact the water in a way that may rudder or skid the transom in the direction you are landing and possibly causing or amplifying some chine walk. Also think of it this way: a tab at vertical is 100% rudder and a tab at horizontal is 100% lift but only when the hull is flying level R to L so less angle is more lift and less rudder effect.
LMAO. Hey you don't know how something works until you try it!
http://www.offshoreonly.com/forums/i...es/cartman.gif
