Fukn a what do I do for steering
#32
I know this was mentioned and it can be a great way to go unless you have all the hardware already.
I needed hydraulic steering and wanted a clean install. Sold my drive and put on the Merc ITS. It didn't really cost much more in the end and was a nice neat install. I could only find one picture and its not a good one!
I think it was $8000 for the ITS and the XR. Maybe $8500.
I figured steering at a minimum of $3500 and an XR.
Less what It got out of my Bravo and Transom assembly.
Something to consider....
#33
I have had great success with the tabs at about 18 to 20 deg. I think that when they are at horizontal and the hull is landing a little right or left then the tab actually will contact the water in a way that may rudder or skid the transom in the direction you are landing and possibly causing or amplifying some chine walk. Also think of it this way: a tab at vertical is 100% rudder and a tab at horizontal is 100% lift but only when the hull is flying level R to L so less angle is more lift and less rudder effect.
Keep in mind it is just a theory!
#35
Think im going to order a hardin / mayfair ” space saver ” wing plate.
#36
Already have all the goods.
Wouldn't mind seeing a close up of that transom if you've got one??
How'd it run ??
