Scarab excel 31 new transom and OB conversion >
Old 11-26-2019 | 02:07 PM
Following the post - what tools did you find worked the best for removing the inner transom rot??
MooresWarlock is offline
Old 11-27-2019 | 07:34 AM
First I took my little Ryobi electric saw. Cut cross patterns in the glass and through most of the wood making sure it could not hit the hull glass.
Used a prybar and hammer after that and that got most of it. Used a grinder to cut the edges of the glass. Hard to get to areas I used a vibracutter. On the stringers I used a sawzaw. About 80 percent of it went very fast. The edges along the bottom took a while and a ton of effort. But got through it after many itchy days.
Dropped her off yesterday at the glass shop. Will go over Monday to get the quote and plan to get her going again.
Gunradd is offline
Old 11-27-2019 | 09:34 PM
Default Great Work!!!
Thx for the update I'm starting my transom reconstruction this weekend!!!
Old 11-28-2019 | 07:49 AM
post some pics! Would love to see it.
Gunradd is offline
Old 11-30-2019 | 04:27 PM
Cut out the gauge cutouts. Started mocking up card board templates on how I’m going to do the panel.
Gunradd is offline
Old 11-30-2019 | 05:34 PM
For the transom, every outerlimits since mid 2004 has a Penske/coosa style transom layup. Don’t overtorque the hardware by a ton and it will be fine. My boat has over 400 hours in the north east, not sure it’s ever been on a lake and 0 sign of issue or compression.
Unlimited jd is offline
Old 12-12-2019 | 04:39 PM
New Penske board transom installed along with the braces needed for the outboards.
they will fill and gel coat next. Should be picking her up next week.
will keep working on the electrical until the bracket is ready. I drive to Miami to pick up bracket the second weekend in January. Should be getting engines mounted on by the end of January.
Gunradd is offline
Old 12-13-2019 | 07:28 PM
Started filling the holes on the console and glassed the top of the new flat panel. Will glass it into the console tomorrow.
Gunradd is offline
Old 12-17-2019 | 04:17 PM
Transom is done
now will be working on the wiring until the new engine bracket is ready. Should be picking it up January 11th. Should have engines on by the end of January
Gunradd is offline
Old 01-02-2020 | 10:42 AM
Things are moving slow but moving along. Decided to rip out all the existing wire and terminal blocks. Going to rewire the entire boat accept for the cabin.
I decided to go with twin 300s instead of the trips for now. Might stick a 3rd in the future or get bigger motors. I picked these up for cheap and starting to get them prepped. Need to sand and paint cowls.
bracket should be completed next weekend so will pick that up and get it put on.
Gunradd is offline
