Fountain 47, 2372cid single engine diesel
#571
oil capasity is about 27liter, 2-3liter doesn't come out in oil change. I have 208liter drum of SAE40, it's pretty cheap. 30w-50 or 30w-60 oil could be best for this but they doesn't exist.
#574
Bypass filters: my theory is they are best used to polish the oil. The idea that the oil is maintained clean.
Particualte filtration has specs for % filtered on 1st, 2nd pass etc.
The intent would be to have very clean oil, and not pass a large particle for an engine failre or issue etc. from a pressure relief bypass.
Main oil feed has a simple filtration to spec, (21 micron in this case) then feeds the system.
The WiX racing oil filter a lot of guys use on the their perf marine engines are 61 micron. Way to large for me. Better to have multpiple filters in parrallel, with a finer filtration.
#575
Back in another life I found moisture in my oil was causing my filters to stop flowing. Seems that the filter media was the problem. In my case source of the moisture was the headers.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
#577
#578
I have found diesel leak in oil place!
First I bought simple pressure tester, this can pump vacuum or 3bar overpressure.
Next I pressure tested injector return lines and find out that left bank line didn't hold any pressure, right bank keep 2bars.
injector lines was pretty loose too. pump side was tight but injector side was loose, wierd because I tightened them pretty tight in last air bleed, Injector line pressed cone have to change shape so thread piece get loose.
