rebuilt trans dosn't work? >
Old 05-23-2006 | 07:34 PM
Scarab3DMC's Avatar
Angry rebuilt trans dosn't work?
I had a local Merc Mechanic rebuild both of my Borg Warner 72-c trannys....put the motors and every thing back together..fired them up today...Starboard works great ...port does NOTHING...FORWARD OR REVERSE...????any suggestions???..I hate to think of pulling the motor again....
Scarab3DMC is offline
Old 05-24-2006 | 06:10 AM
Pwrbt33's Avatar
Default Re: rebuilt trans dosn't work?
If you have nothing and the fluid is not being pumped, he may have set the pump up for reverse rotation by accident. Start the motor up and crack a line loose to see if you have any fluid movement in the hoses. You cant really put the shuttle valve together wrong. Usually when the dont work, its the pump housing is clocked wrong.
Sorry for the bad news if thats it. You will have to pull it out.
John S.
Pwrbt33 is offline
Old 05-24-2006 | 06:43 AM
Mbam's Avatar
Offshoreonly Advertiser
What he said.
Mbam is offline
Scarab3DMC's Avatar
I'll try that,,,thanks...Dave
Old 05-25-2006 | 07:23 AM
Scarab3DMC's Avatar
THANKS GUYS...EXACTLY CORRECT !!!!, PULLED THE MOTOR FRONT COVER WAS 180 degrees off... now I know what you ment by "CLOCKED'' wrong...thanks...Dave
Old 05-25-2006 | 08:02 AM
gotime34's Avatar
This same exact thing happened to me last season, but with both sides. Had to pull them both...I was not happy.
gotime34 is offline
Old 05-25-2006 | 11:12 AM
Pwrbt33's Avatar
Glad to hear that was it! Hopefully it wasnt to much trouble.
John S.
Pwrbt33 is offline
Old 05-26-2006 | 08:08 AM
Scarab3DMC's Avatar
I installed trans pressure gauges & senders...but I can't get them to work..I ran 14 gauge wires to the gauges...I have a good ground..I turn the ignition on and the needles move up 3/16''..I installed the senders in the 1/8 pipe plug next to where the old temp sender was 3/8 pipe...I noticed another 1/8 plug on the front cover..I was told thats "reverse" pressure... ??gauges and senders are Livorsi...
Old 05-26-2006 | 08:17 AM
J-Bonz's Avatar
Dave,
Sorry, i dont have any advice but, keep us posted. I am looking to do the same here.
Jr.
J-Bonz is offline
Old 05-26-2006 | 08:27 AM
Mbam's Avatar
The 3/8 plug is the line pressure.
Mbam is offline
Wally
6
06-27-2006 08:22 AM
Face It
5
02-06-2004 07:36 AM
fastedy
General Racing Discussion
30
01-26-2004 12:01 PM
nauticaL ILLUSIONS
7
07-22-2003 12:16 PM
hystat
2
05-27-2002 05:35 PM
