Just Turbines
Old 01-06-2014 | 05:57 PM
  #281
KNOT-RIGHT's Avatar
now see the inner lip.
Here is a pretty cool internal puller that extracts it.
KNOT-RIGHT is offline
Old 01-06-2014 | 06:01 PM
  #282
KNOT-RIGHT's Avatar
this is the last item to remove before the diffuser
it is a carbon seal so one must take caution not to chip it.
make sure you dont do what i did and removal all of the diffuser to compressor bolts prior to this.Leave atleast 4.
Old 01-06-2014 | 06:04 PM
  #283
KNOT-RIGHT's Avatar
it required some heat as i smacked down on the diffuser with a rubber hammer is started to go
looks like this
Old 01-06-2014 | 06:10 PM
  #284
KNOT-RIGHT's Avatar
here is all the components that make up the number too bearing and seal.
the bearing housing and pinch plate and seal retainer is getting swopped out for the reworked versions.
this is all about keeping these items cooler
Old 01-06-2014 | 06:14 PM
  #285
KNOT-RIGHT's Avatar
removed the remainder of the compressor to diffuser bolts and whacked upward on the diffuser with a rubber mallet
and she finally let loose
Old 01-06-2014 | 06:17 PM
  #286
KNOT-RIGHT's Avatar
here it is waiting to be crated and sent to PPS for machining
Old 01-06-2014 | 06:18 PM
  #287
KNOT-RIGHT's Avatar
here is the flip side.
I wonder if these will ever run right again
Old 01-07-2014 | 06:47 PM
  #288
KNOT-RIGHT's Avatar
17 inch Mitsubishi rim worked for the second motor
vertical is much easier.
saws alled the spokes out
Old 01-07-2014 | 06:52 PM
  #289
KNOT-RIGHT's Avatar
Old 01-07-2014 | 08:33 PM
  #290
damdonzi's Avatar
I amend my previous post to assert that there is not enough beer in New England for this type of Winter "fun"...if you will. Forget just RI.
damdonzi is offline
