Just Turbines
Old 02-14-2014 | 08:18 AM
  #381
KNOT-RIGHT's Avatar
hour and a half later i got this piece of work
KNOT-RIGHT is offline
Old 02-14-2014 | 08:35 AM
  #382
Nice job Gerry! Very interesting aNd informative! You will try anything!
Unlimited jd is offline
Old 02-14-2014 | 09:59 AM
  #383
Good job. No more holes, please. That's a plenty ! You need mass to take on and dissipate the heat. U do work, I C, lol. Now show us the HUBS.
I'CE is offline
Old 02-14-2014 | 12:16 PM
  #384
jvthundercat's Avatar
Nice thread! I have done some jet work back in the day myself. I can still twist a mean wire plier too.
I just ran across three portable start turbines in good condition cheap with some friends of mine.
I will have to run the numbers to see if they are big enough next time I get up there.
I suppose I could buy one just to piss off the neighbors. lol
jvthundercat is offline
Old 02-14-2014 | 12:25 PM
  #385
jv, what type/kind of Turbines you talking about? any pictures can you describe how these set ups work? thanks
I'CE is offline
Old 02-14-2014 | 02:48 PM
  #386
One's hanging on Planes. C-5, C-141, A-7, F-16, F-5, and 3.5 yrs on President Regan's E-4b.
Engines and APU's. It was called USAir Force for 6 yrs. Flight Line, Over haul, Test Cell, Inspection. etc.
Old 02-14-2014 | 05:42 PM
  #387
KNOT-RIGHT's Avatar
Thanks Jaime!! i need to keep myself busy otherwise i may find myself waking up in a strip joint.
here is the hub that the rotor bolts to the center spline is worn allowing rotor runout
Old 02-14-2014 | 05:46 PM
  #388
KNOT-RIGHT's Avatar
it is a 32 spline on a 2 1/16 shaft
i am pretty sure SCS made this if have a call into Craig over there now will see if he can machine a new one.
here is the spline inside the crashbox bell housing
Old 02-14-2014 | 05:48 PM
  #389
KNOT-RIGHT's Avatar
cool those Little turbine can throw some hp considering the size.
APU aux power unit
they usually are used to start a bigger turbine
Old 02-14-2014 | 07:52 PM
  #390
APU aux power unit
Yes
