Just Turbines
Old 12-29-2013 | 07:47 PM
  #261
KNOT-RIGHT's Avatar
Originally Posted by Coolerman
Gerry, are you still running 6's or did you get arnesons?
Currently still sixes although i have been chasing some Arnesons locally.
KNOT-RIGHT is offline
Old 12-30-2013 | 08:27 PM
  #262
Originally Posted by KNOT-RIGHT
i run a 30 gallon poly tank. The spray rails incorporate 20 1/16 jets x 2 engines i would estimate it would deplete the tank in approx 15 minutes.
The engines will run within there egt limits. Unless the ambient temp is over 100f.
Im guessing that enlarging the intake ducts and the combustion swirl slots being enlarged will help the egts.
interesting points Curious as to your cruise range?
I have a total of 314 gallons (257 main and 57 forward) so I can go about 600 miles. But I usually start with 150 gallons run it down to 40 or so and put another 100 in unless I am going to the Bahamas for a week then I fill both tanks. I get better MPG running 50/50 water/Meth but what I save in diesel I spend x4 in Meth so its not worth the $$$ and hassle for MPG alone, I thought about using the forward 57 gallon tank for a dedicated water/meth tank but for the limited amount of time I could really use the extra 30hp (at WOT) its not worth it, I mean if I am going 55 or 57 does it really matter? I may reinstall the water injection system and just set it up to run when I get over 1100 EGT and it will last about 7 hrs off of the 40 gallon freshwater tank. (175ml/min x2)
But in your case couldn't you add more fuel which normally would cause an EGT problem but offset it with the water injection, apples and oranges I know, my engines only make 325hp each
pstorti is offline
Old 01-06-2014 | 04:55 PM
  #263
KNOT-RIGHT's Avatar
thats some great fuel consumption
Some day i would love to build a diesel boat.
Ok on with the count down.
We need to go vertical a f350 rim provided a stable base
H
Old 01-06-2014 | 04:57 PM
  #264
KNOT-RIGHT's Avatar
we go after the forward cone which is threaded internally not like the
aft cone which is external.
Here is the slide hammer with adapter
Old 01-06-2014 | 04:58 PM
  #265
KNOT-RIGHT's Avatar
here it is
Old 01-06-2014 | 05:00 PM
  #266
KNOT-RIGHT's Avatar
the pinch plate is now exposed along with the bearing housing
Old 01-06-2014 | 05:04 PM
  #267
KNOT-RIGHT's Avatar
it is now easily removed
Old 01-06-2014 | 05:06 PM
  #268
KNOT-RIGHT's Avatar
here is the flip side the pinch plate and bearing housing is shown here together
Old 01-06-2014 | 05:08 PM
  #269
KNOT-RIGHT's Avatar
as we move forward we are ultimately removing the diffuser housing so we can machine it with the scallops similar to the bearing housing shown above
here is the bearing which we need to remove next
Old 01-06-2014 | 05:13 PM
  #270
KNOT-RIGHT's Avatar
look closely you can actually see the marks where the scallops are going
i am pointing to the crush seals which need to be replaced at reassembly
