Just Turbines
Old 08-06-2020 | 08:49 PM
  #701
old stuff
twin rudders
I'CE is offline
Old 08-06-2020 | 09:00 PM
  #702
just for kicks, how an old school aluminum boat is in frame
another up an under
not easy to find a nice aluminum boat these days
I'CE is offline
Old 08-06-2020 | 09:03 PM
  #703
rudders behind the wheels actuated by cables
I'CE is offline
Old 08-07-2020 | 08:05 AM
  #704
look at an great airplane the DC3 thats still flying ......all the controls are cable operated it was a great reliable system that did not leak
boostbros is offline
Old 08-07-2020 | 08:33 AM
  #705
KNOT-RIGHT's Avatar
Thumbs up
Originally Posted by 999JAY
Overall do you think the swap from #6 to BPMs is going to be worth it, I would imagine annual maintenance is going to be a lot lower and efficiency is better.
With regards stability, the BPMs seem to run a lot looser but I suppose that's to be expected with the reduction in drag over the SSM
Difficult to say at this point. Need more seat and setup time. Overall i think its more efficient.
Next test run after we address engine cooling issues. I will have gopro cameras in place monitoring as many angles as possible.
The trim should be moved to its upper extreme and lower extreme with a steady throttle. This will help to assure i have my boxes/trim rams height close.
some random thoughts on further setup ideas.
propellers.
trim height.
prop rotation
better video on gauges vs mph
Im sure we can come up with more?
The placement of the sixes on the 46 is a known value.
Placement of fixed shafts with rudder is not.
KNOT-RIGHT is offline
Old 08-09-2020 | 11:54 AM
  #706
Next time your out can you get some more video to get a better idea of how the boat is running, if you can shoot this landscape would be better to get more in.
999JAY is offline
Old 08-11-2020 | 10:26 AM
  #707
KNOT-RIGHT's Avatar
here is the video from that day from the support boat
Old 08-20-2020 | 11:56 AM
  #708
KNOT-RIGHT's Avatar
went out again yesturday
motors still overheating
maybe exhausts getting drawn into intakes.
anyway got a ton of these too actually see if i got setup height on bpm right
this all up just about
Old 08-20-2020 | 12:52 PM
  #709
KNOT-RIGHT's Avatar
Default Trim down
Old 08-20-2020 | 12:54 PM
  #710
KNOT-RIGHT's Avatar
Default All up
looks like it could down more
