make over inputs needed >
Old 03-20-2009 | 02:44 PM
Are you talking about the lil trapezoid vent where the horn is?
commandersander is offline
Old 03-20-2009 | 03:29 PM
It is the one that was black and now yours are white. The are about in the middle of the cockpit on the outside.
jmrapp is offline
Old 03-20-2009 | 11:07 PM
Those (on mine) came out fairly easily. I used an Olfa knife to cut the sealant and then pryed them out. Then, I thoroughly cleaned them with laquer-thinner (fast) and set them is the sun prior to spray bomb Rustoleum gloss white.....about two years ago....
Old 03-21-2009 | 07:59 PM
Originally Posted by jmrapp
How hard was it to get the side vents by the windshield off? Or were they not removed? Mine are in need of some attention.
They are just siliconed in. Should come out pretty easily. Clean them up a little. Use a plastic primer (available at any auto parts store, used to prime the plastic bumpers and stuff on cars today) before applying any paint.
I did mine on my 91' 292, used the plastic primer, the gel was a match to Johnson outboard paint in a can, then used a couple coats of clear to top it off. Then just silicone back in.
Did the same to the grab handles and step plates also.
Attached Thumbnails make over inputs needed-boat-001.jpg   make over inputs needed-boat-003.jpg   make over inputs needed-boat-004.jpg
Treads is offline
Old 03-22-2009 | 05:40 PM
mtgbiker's Avatar
IMO, new "White" Rub Rail for your boat would look awesome. See thread "New Taco Rub Rail" in Formula Forum I started.
http://www.offshoreonly.com/forums/f...-rub-rail.html
mtgbiker is offline
Old 03-23-2009 | 09:49 AM
Thanks! I will use black most likely.
jmrapp is offline
Old 03-23-2009 | 09:59 AM
Originally Posted by joker9r
Enjoy
Armando
Photophix is offline
Old 03-29-2009 | 06:15 PM
Default Update
Well here are some photos of the progress.... still waiting for pictures of the vinyl work and pics of the new alluminum swim platform mounted... I think I'll go back to the original black dash panels... the red is too busy! Man I need some new guages and bezels!
joker9r is offline
Old 03-29-2009 | 06:24 PM
love that photofix
88242LS is offline
LubeJobs42
06-02-2007 06:02 PM
rangerrick63
2
11-20-2006 06:20 PM
LubeJobs42
04-29-2006 08:05 PM
BryanTuvell
9
11-04-2002 12:49 PM
