Thad Allen's Apache + The Birth of the Cheetah Cat
#541
so an easy to use readily avaliable source. I had a similar situation when i first started trying to bag stuff. I had some molds that i was making wet parts out of and i wanted to try bagging some parts. The molds were an odd shaped and difficult to figure out where to pleat (at least for me lol) I had a huge surplus of these big four foot by five foot industrial bags, not sure what they were for but they were on the thick side and polyethelene. Any way the molds fit inside the bag and all i had to do was seal the opening and pop on a port. Worked pretty good and about all it stuck was the consumables so no biggie, tear 'em off and throw 'em out
back in the late 80s when I was engeering a electronics printed circuit board process , we use large "turkey" bag that we would put a heavy steel lamination fixture inside of it and seal the end except for the vacuum port, we load them in a cool lamination press and pull vacuum for about 15-20 minutes then close and heat up the press and laminate the B stage pre-preg to the C stage core material. the steel fixture kept everything in alined as when we were done we have to drill thru all these C stage core layers.
we used E glass pre pregs.
it is much more difficult then how i stated as we laminated up to 15 to 20 of these C stage cores together
we use heat and pressure to laminate them all togther
at some point later on ,, we even tried a auto clave to do this process.
thank you
Jim
we pull vacuum for about 15-20 minutes and then la
#542
Dave/Steve,
thank you
Jim
thank you
Jim
I made the Vacuum pump out of a blasted Air raid warning siren and a 10 HP electric motor, the laminate we were doing would get spotty after 4 HG so the pressure levels were critical,
That was the madness behind the regulator controlled system and that body shop film allowed masking tape to stick and seal close to a tacky tape. the time constraints forced the Co-Bag operation where the laminate and core were done One shot.
I needed a pilothouse a day.
and I was training my crew as we went along.
#543
8000 miles from home and having to make do with whatever we could find.
I hate hand contact open faced molding and will always try to find the material to do a even rudimentary closed mold system, My Dad taught me not to cry about what is not working or missing But find one thing positive and start up from there.
There were a lot of junk yards there filled with war damaged material of all kinds. That was a source for my vacuum pump, the pressure fed roller made from a busted road stripe machine that the pump survived,The gelcoater the same way, this was the way I worked until the Venus machines were shipped in.
#544
Steve
Thank you,,
Jim
#546
Musta been awfully noisy in the shop when you had to bag something
08 OPA High Points Champion
#547
LOL I had to have a muffler made and a 12 meter stack even though I was using the intake side it was still very noisy and had people running out, But it worked very well,I did the barrel crush test for the Kuwaiti's they were shocked how fast it destroyed the steel drum.
#548
probably tough to get anything done when ya fire up the pump and your work crew dives under a desk (I'm just full of 'em today
so . . . . I'm think'in i should try this barrel crush test with my new pump. Whats involved, just seal up a drum and hook up the pump? I do have a couple of 55'ers i need to get rid of. How small they get?
How much lbs/sq inch does 29 HG convert to?
) so . . . . I'm think'in i should try this barrel crush test with my new pump. Whats involved, just seal up a drum and hook up the pump? I do have a couple of 55'ers i need to get rid of. How small they get?
#549
oh wait thats a perfect vacuum and about 14 psi or something like that.
#550
