Thad Allen's Apache + The Birth of the Cheetah Cat >
Old 12-10-2010 | 06:54 PM
  #611
Steve 1's Avatar
+1
Hi Steve hey did you get a chance to look into Diab's line of products and see what foam they have is comparable to the 6lb Airex that was used in the Talon race boat i have to fix? Is Airex still available? Just looking at my options. Thanks
Dave I went through their Data sheets ,aside from them crying about Gurit and the corecell M foams,the only thing I would recommend is using a H-100 you should be safe there on the hull Side,Now the bottom I would go with the H-130 to have a reasonable margin of safety.
They have a lot of material,but again the H is the only one to have some history.
Steve 1 is offline
Old 12-10-2010 | 07:02 PM
  #612
Steve 1's Avatar
Here is the R63.80 Airex.
There is nothing close except, A 550 Corecell.Now that said, this is the reason I went with the heaver "H" core since I had only Diabs Cupboard to root around in.
Steve 1 is offline
Old 10-03-2011 | 10:03 PM
  #613
glassdave's Avatar
Neno the mind boggler
Great thread . . . . I re-read it from time to time for fun
Thanks again Steve for the info on the Diab products that helped out a lot on that project.
08 OPA High Points Champion
glassdave is offline
Old 10-03-2011 | 11:01 PM
  #614
Steve 1's Avatar
Sir, anytime and thank you for the compliment, we are all brothers in the high-speed grinder corps.
Steve 1 is offline
Old 10-03-2011 | 11:40 PM
  #615
glassdave's Avatar
Steve can you PM me your email address. I want to send you those pics of rebuilding the sponson on the Talon. Fun stuff . . . .
High speed grinder corps . . . .
Old 10-04-2011 | 06:27 AM
  #616
Jolley's Avatar
I 2nd That 'High Speed Grinder Corps'. Great qoute. Love this thread, please post more Steve if you could ? Again One of the most informative threads ever !!!!
Jolley is offline
Old 01-14-2012 | 04:32 PM
  #617
Very interesting to read the thread. When you you started to build composite boats I think I was still steam bending oak frames and clench nailing lap strake planking.
I always seemed to be about 15 years behind you. First with Flats Skiffs and now Catamarans. Let me know what's in your bag now, so that when I turn 75 I will know what to do next.
Jim
mini max is offline
Old 01-14-2012 | 05:05 PM
  #618
Steve 1's Avatar
Jim
Thanks for the complement ,this from from the Best Boatbuilder I have Ever worked with,Very nice looking Cat there!!Jim currently Looking at setting up and doing some pressure baked stuff ,How are you doing?
Here is one of Jim's Carbon Fiber jobs hanging from the crane,IMHO was the tallest one piece CF mast in the world ,back When built.
Steve 1 is offline
Old 01-15-2012 | 11:12 AM
  #619
I remember very well you demonstrating the water tubing level you described using a 5 gallon reservoir. Can you believe that was twenty five years ago? As a teenager I tried clear plastic tubing, but no reservoir to level a canoe mold and it drove me crazy.
Later when I was in High school, My Dad who had been a surveyor for the Pennsylvania Rail Road prior to WW II, served on our communities school board when they built a swimming pool. He specified a "Fast Pool", meaning that the gutter tiles had to be within 1/4" of the water level so when the swimmers completed a lap the waves they made would drop into the gutter easily and there would be no resurgent bounce to "Slow" the swimmers on their return. Fast Pools for Dummies would suggest to use The Koss water level scheme or fill the pool and mark it before setting the tiles. The contractor had shot the curb with an engineer level. My dad checked it and it was "perfectly level", but the water was "off". This caused great consternation. I was into celestial navigating with a sextant and the first thing you learn is that the earth is round. They shot a level line to set the curb, tangent to where the transit level was set, but the earth and the water is round, and dropped away so the water was only close to the curb at the end closest to where the Level was set up.
You see Steve, all this time, the reason your boats are so "Fast" and not "slow" is that you have been setting up your mold stations to be "water friendly" all these years !!!!!!!!
Note: for a 6' tall man standing on the beach, the horizon he sees is only 3 miles away. After that, you fall off the edge.
mini max is offline
Old 01-15-2012 | 12:54 PM
  #620
Steve 1's Avatar
Jim Great Post, There was a guy doing some precise contract work for the navy; anyway they came in during his setup and asked him, how he was compensating for the change in his building when the tide came in, this since the place was on the water, he said there was no measurable change, they left “Their” indicator there and low and behold there was tidal caused deflection, this was a while back.
Forget where I heard that story, most likely in a mad search of equipment splitting degrees into many pieces and fractions.
Water, I have always preferred that to about everything I have including the high-end lasers, plus it does not flash you and one man can use it, does not need cleaning or repair will not ever wear out, maybe some of the same water that the Egyptians and Greeks used.
Steve 1 is offline
