Thad Allen's Apache + The Birth of the Cheetah Cat
#111
I apologize for putting in these pictures in way out of order,But I did not have them when I started and currently waiting on 50 More to finish this with
#113
Sharp carbide cutters here ,the Box cove setup was on the other side of the table, I wanted two setups end to end but there was not the room so I flipped the work over and handed it to a helper on the other side.
#114
In this business it is a matter of steps you make a mistake on step one and at step 5 you find it Guess what??????? Check Check double check.
This:
This:
#117
and then this: Steel Beams on steel cross spars shimmed to elevation with sheet metal and Formica shims.
#118
the way I had these frames cut they were "nested" saving plywood and making it easer for me to handle what was essentially a stack of Plywood. Marine Concepts, I can't say enough good about them really nice people there and Knocked this out Very Quick for me.
Like I said before usually there is a full size Loft in my operation and I pick up from the loft and cut them myself.
The top sheet has the first frames and that little one that looks like a tuning fork is frame #1 in reality.
