2nd time here we go again clanking ticking noise after engine shut down >
Old 09-07-2021 | 01:02 PM
  #61
why not go with roller rockers? even a cheap amazon clone set
boostbros is offline
Old 09-07-2021 | 01:06 PM
  #62
SB
Originally Posted by SB
I forget, What blocks are these ? Has this been an issue since you owned them ?
Originally Posted by 35fountain
gen 4 509 no just eats up rockers ...apparently an oiling issue on top
heads are 781 gm...old oval port but good up to 650hp
I asked about block.
SB is offline
Old 09-07-2021 | 01:43 PM
  #63
35fountain's Avatar
if they fit under stock low profile valve covers I would... I haven't found a set yet. Everyone says the polylock will hit the cover.
2 piece valve covers too expensive for me lol...I can get my covers off in 10 minutes lol and i don't need to remove the exhaust
35fountain is offline
Old 09-07-2021 | 01:45 PM
  #64
35fountain's Avatar
I answered you....gen 4 502 bored to a 509 mercruiser 1990-1992
Old 09-07-2021 | 01:50 PM
  #65
SB
Um, no. But that's okay. SOunds like you may be saying OEM GM 502 block Gen IV. Many other gen 4 block makers out their. Darts have a lifter oiling issue. More specifially stated above.
What lube did you put on the rocker balls when first installed ?
What doe your oil psi gauge say when idling ?
Anyway you can see if machine shop that set up heads has closed and open psi of your springs ?
You said valves have .100" longer valves. Did someone figure out pushrod length requirements when these heads where added ? Or are you using stock length pushrods ?
SB is offline
Old 09-07-2021 | 02:04 PM
  #66
Veteran: Army
I think the later 502 style low profile covers may get you more clearance.
DrFeelgood is offline
Old 09-07-2021 | 02:15 PM
  #67
35fountain's Avatar
What lube did you put on the rocker balls when first installed ? Red cam break in lube
What doe your oil psi gauge say when idling ? 80 cold 60 warm after a hard run never drops below 40
Anyway you can see if machine shop that set up heads has closed and open psi of your springs ? I don't remember that one I know they were in specs with those double springs with dampers. I watched them test them.
I bought boat with these engines.
I don't know about the pushrods but I have an old intake 3 piece pushrod from this boat.. One of the the balls came off. luckily was laying by the head bolt. I then changed all to 1 piece
It measures 8.280 intake stock length
Old 09-07-2021 | 02:21 PM
  #68
35fountain's Avatar
if those pics showed galling then I would say there is the noise. When the engine shuts down the pressure is no longer in the lifters so they will start to bleed down correct?
if the rocker balls are worn not smooth you can get a ticking? because they aren't smooth moving ?
Old 09-07-2021 | 02:23 PM
  #69
35fountain's Avatar
Can anyone recommend a high zinc oil to replace the amsoil synthetic.. Vr1 20-50 mineral or vr1 synthetic.. or ?? possibly change to a 15/40
Old 09-07-2021 | 02:52 PM
  #70
F-2 Speedy's Avatar
many of us run this, Im not a fan of synthetic in a boat
F-2 Speedy is offline
