Tunell raaammm!!!!
#51
I have a couple new sets I powder coated merc blue of the Hardin style but was wondering about the 2 piece. Are they not really what there suppose to be? Pretty sure I’ll be able to remove mine without sliding the stellings back??? Engines not in the boat yet.
#52
Hardin might have corrected them. I know S30 has posted how he ground areas away to help.
Sorry ICPPLPEEING for the derailment.
#55
Charter Member #40
As a stock replacement they leak. You can grind down the inner rail on the base at the rear corner which helps. With that cover you usually have the spring spray bars in them which only adds to the oil laying on top of head. I usually had oil return lines plumbed into the head going down to pan which helps keep oil a little cooler and definitely reduces the oil available to leak. Main benefit from my standpoint is time and accessibility. Oil absorb pad in bottom of hull usually takes care of oil problem. Comes down to a cost versus benefit question for the individual.
#56
[QUOTE=bob;4813405]
Darts have the pad to mount the injectors at the port. One of KE's main reason for staying with the Dart historically. I think probably the Profiller flows a little more. With either intake, port flow is a world of difference compared to the conventional blower intake. No 90 degree bends at the port. Mid range is a world of difference .
The profiler is hands down the best OTB tunnel ram HP wise.
#57
They just leak like a sieve. It's like a constant oil change. Put oil in the fill hole on top, run boat for a few hours, the valve covers automatically drain oil to the bilge, top off with another 1/2 qt, drain bilge from the oil plug on the back of the transom.
head down to post 29 and beyond
Boatfreaks
#58
You have been banned for the following reason:
No reason was specified.
Date the ban will be lifted: Never
