Water pickup for intercooler
#33
How did you find the flow differences for next down level adjustment? Was it on the fence or just way too much water? Pop-off valve always open....!!
#34
#35
On Bad Kitty I got rid of some useless trans temp gauges and replaced with intercooler water pressure.
Used this strainer.. last engines they were mounted on the head which is even nicer but I don`t have any room on the new ones.
#36
#37
The reason I made the angle cutter was to achieve a consistent gap around to pickup tube for the 3M adhesive. I first cut an oversize hole with a hole saw then filled it with fiber reinforced epoxy, then machined it to accept the pickup tube and adhesive. Overkill I know, but I can't help it.
