Stringer Replacement Formula 302 >
Old 02-18-2004 | 11:01 PM
  #91
Audiofn's Avatar
Charter Member #232
This picture shows a problem that I had to overcome. It worked out perfect however. The rear bulkhead was replaced two years ago. The guy that did the work installed the bulkhead but did not treat the one side The bulkhead bowed out and needed to be pulled back into place. To do this I used ratchet straps. This solved two problems. One was how to get the bulkhead back to were it belonged. The other was how to hold the stringer in place.
Attached Thumbnails Stringer Replacement Formula 302-44-stringer-tabbed-small-.jpg
Put your best foot forward!
Audiofn is offline
Old 02-18-2004 | 11:03 PM
  #92
Audiofn's Avatar
Charter Member #232
What a difference with just the one stringer replaced!!!! The bulkheads are stiffer then they ever have been and the new stringer seems to have stiffened the bottom nicely.
Audiofn is offline
Old 02-19-2004 | 08:32 PM
  #93
wwwTOPDJcom's Avatar
looking good Jon
wwwTOPDJcom is offline
Old 02-19-2004 | 08:49 PM
  #94
Audiofn's Avatar
Charter Member #232
Thanks Top.
Today I got the foam around the other stringer out and then cut out the stringer. It is amazing how BAD the rot was on these things. They weigh a TON and just fall apart!!! I hope to have the new one in by the end of the weekend but realistically it will be a little longer then that as work is SUPER bussy.
Jon
Audiofn is offline
Old 02-20-2004 | 05:53 AM
  #95
32storm's Avatar
Serious urban renewal project. It'll be tough to follow-up on this one.
32storm is offline
Old 02-20-2004 | 07:45 PM
  #96
Audiofn's Avatar
Charter Member #232
Sutphen I will be at the shop tomarrow AM tell about 1:30. So if you can make it up before then that would be cool. I plan on being there Sunday as well, still not sure of the hours.
Jon
Audiofn is offline
Old 02-20-2004 | 07:55 PM
  #97
ragtop409's Avatar
Hey Feelin' Nut's, YOU are an animal LOOKS awsome dude Rag's
ragtop409 is offline
Old 02-20-2004 | 09:59 PM
  #98
glassdave's Avatar
Neno the mind boggler
yo jon . . .i put of my cinnci trip for a week or so, i will get ahold of you when i get back and let you know whaa-zup
08 OPA High Points Champion
glassdave is offline
Old 02-22-2004 | 07:24 PM
  #99
Audiofn's Avatar
Charter Member #232
This is the old stringer.
Attached Thumbnails Stringer Replacement Formula 302-47-old-stringer-small-.jpg
Audiofn is offline
Old 02-22-2004 | 07:25 PM
  #100
Audiofn's Avatar
Charter Member #232
Hey is this a bad thing?
Attached Thumbnails Stringer Replacement Formula 302-48-old-stringer-small-.jpg
Audiofn is offline
