Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
Lake St Clair Magnum's >
Old 10-06-2011 | 09:19 AM
  #1011
mr vinyl's Avatar
Default Hinged seat
We hinge the entire seat forward and the down. We have step plates over the batteries and the 1st stringer of the engine compartment is cut down a little,providing great access to the engine bay.The entire seat can be removed easily by just unscrewing the piano hinge from the seat base. Bud
Attached Thumbnails Lake St Clair Magnum's-img_0810.jpg   Lake St Clair Magnum's-img_0796.jpg   Lake St Clair Magnum's-img_0797.jpg
mr vinyl is offline
Old 10-06-2011 | 09:25 AM
  #1012
mr vinyl's Avatar
Default Hinged seat
Two more photos,engine compartment and rear seat removed. Bud
Attached Thumbnails Lake St Clair Magnum's-035.jpg   Lake St Clair Magnum's-47-1-.jpg
mr vinyl is offline
Old 10-06-2011 | 12:29 PM
  #1013
dammmagnum's Avatar
Originally Posted by h2oboater
The top of the back seat flips forward. I'm going to modify the catches, it does make it easier to work on. I plan to cut the floor and add foot wells like I had in my old mag. After the run we did in Apache Johns yellow Mag I know I need stand up seats. The boat needs to be taken down to a blank hull cleaned up and re rigged. But until I run it I wont know for sure. Here is a pic of the back seat & hinge.
Mark - Bud,
Nice Set up with the hinged rear seat,, any idea how the strength is affected with engine bulk head hindged, and removed across the top?
Thank you
jim
dammmagnum is offline
Old 10-06-2011 | 12:40 PM
  #1014
mr vinyl's Avatar
Default Hinged seat
Because it was a racing Maltese,no cockpit liner,flat floor,additional cross floor rib bracing and came came from the factory like that do not notice any flex. Bud
mr vinyl is offline
Old 10-06-2011 | 10:46 PM
  #1015
h2oboater's Avatar
Originally Posted by dammmagnum
Mark - Bud,
Thank you
jim
Jim on my race sport were removed the back seat when we put the Lil Smidgen race hatches on her. Being my Mag would be raced we added a aluminum c channel tieing the sides together. It would not be hard to add a brace that you could remove when needed. This pic's shows the c channel we added.
Mark
Attached Thumbnails Lake St Clair Magnum's-mag-p-88-eng-h2o.jpg   Lake St Clair Magnum's-mag-p-88-c-channel.jpg
h2oboater is offline
Old 10-06-2011 | 11:18 PM
  #1016
h2oboater's Avatar
The Mag made it into the water today. I was a little nervous that with the drives raised 3 inches that it would be a little hard to get on plane, NOT!!! I ran it for about 20 minuets with no problems. One of my concerns was the fact it was not running a thermostat. With 60 degree lake water temp the engines temp did get up to around 135 degrees so I did run it all the way out. Bud you were right this Mag flies for what it is. Many who thought this ebay Mag was beyond saving, this test put that Idea to rest. Now the fun begins to restoring this classic Mag.
Attached Thumbnails Lake St Clair Magnum's-mag-sport-fall-2011-h2o-006.jpg   Lake St Clair Magnum's-mag-sport-fall-2011-h2o-011.jpg
Old 10-06-2011 | 11:21 PM
  #1017
Any of you Mag guys running on st. Clair this weekend?
POWERPLAY J is offline
Old 10-07-2011 | 01:01 AM
  #1018
dammmagnum's Avatar
Mark
Mark,
Thank you, i thought a removeable brace from side to side would help. I re-inforced my engine bulkhead with glass when I got my Sport, as i was told that was the area that they would crack, not really sure if that was needed or not?
Great about getting your Sport wet today , nice feeling when you get back in the water,, and as you said,, now the fun can begin
i know you will keep us posted on your progress..
Thank you
jim
Old 10-07-2011 | 08:26 AM
  #1019
mr vinyl's Avatar
Default Mark your Mag
Always a problem when you recommend a boat to a friend...however Roger Munn was behind you on this one ...not to worry.It would be nice to let Allie the previous owner know,he has asked Roger how it was going. Bud
mr vinyl is offline
Old 10-11-2011 | 11:04 PM
  #1020
h2oboater's Avatar
I was looking through my many Magnum pic's I have and I found these pic's Roger Munn had of my Mag in it's past life .
Attached Thumbnails Lake St Clair Magnum's-mag-new-sport-1973.jpg   Lake St Clair Magnum's-mags-%40-dock.jpg   Lake St Clair Magnum's-mags-beach-ii.jpg
