Bad Kitty, making things happen.
#182
[QUOTE=ICDEDPPL;4934791]Got some new props, did some running this weekend.
Had an oil leak at Thermofilter so didn`t open her up .. new parts ordered .
What props did you test, Dia x Pitch - Rake? From the look at the gauges RPM/MPH in video it would be around a 28 pitch with 10% slip.
That is a far cry from what was on the rig in the first place and the 33 pitch you were looking for. Asking as I am doing a whole new setup as well, Engines, Drives, X dimension on my Cat.
#184
Wow, that is a lot of slip to begine with then drop to 5%. Sounds like you are on the way to getting it dialed in. 150 is a great number for that boat.
Saw the 4 engine outboard (4 x 400s) converted 3600 here at Lanier for the poker run last weekend. Man it porposed a lot when it went by at about 70-80mph.
#186
#187
I`ve always liked Dexter products... also it`s red so a no brainer
The first 2 took a bit.
Once I figured out that dissasembly is best with no jacks and assembly only needs a jack under the cross bar to bring the second spring closer it was easy after that.
Boat was off trailer of course.
