Go Back  Offshoreonly.com > Owners Forum > Sonic
Finished Some Projects >
Old 02-08-2009 | 04:50 PM
  #31
Plum_Crazy's Avatar
I'm getting there on my exhaust. I had two goals with the turn-downs. I wanted to meet the strict Minnesota 84dB limit and keep the transom clean. So, I had GGB build these custom turn downs that are bolted onto the end of the HPI mufflers. I knew I would have a tie-bar clearance issue in the trailer position, but it was far worse that I originally thought. Imco is building me custom saddle mounts for a lower tie-bar that will move the bar very close to the end of the drive. Then, it will clear on the outside of the pipes.
Plum_Crazy is offline
Old 02-23-2009 | 06:40 PM
  #32
NJSONIC's Avatar
Check out their new web site.http://www.getrealperformance.com/products.php
NJSONIC is offline
Old 02-23-2009 | 09:51 PM
  #33
Plum_Crazy's Avatar
I dig the trim tanks, but check out the product description.
Old 02-24-2009 | 08:09 AM
  #34
Jim Diesel's Avatar
"Unregistered Gun"
Hey Plum any tips on installing the new rubrail, when I pulled my old it had silicone around the bottom of the insert. I was able to clean my holder with acetone and wet sanded the light scratches out, buffed with some polish it looks great.
Jim Diesel is offline
Old 02-24-2009 | 09:04 AM
  #35
Plum_Crazy's Avatar
Soak it in a bucket of HOT water to make it more flexible. That really helps. I believe the pros have a special tool to push it in. But, I just inserted the bottom lip and pushed the top lip in with a flat screwdriver.
Old 02-24-2009 | 10:20 AM
  #36
Jim a buddy of mine and I installed a new insert in the 45 in a hour and a half, including a six pack. get a large flat bladed screw driver and a bottle of spray soap (spray nine works) and a dead blow hammer. Start the insert in on the bottom use the screwdriver to line it up on the top, give it a spray and hit it with a NEW (no dirt or grease) light weight dead and it will pop right in.
45SS is offline
Old 02-24-2009 | 10:25 PM
  #37
GO4BROKE's Avatar
I spent $50 on a heat gun, heated 3', pushed it in with the palm of my hand, had the wife holding the excess so it wouldn't pull out while I heated the next section.
Makes a HUGE difference in how "clean" the boat looks.
When I look at a boat I look at the rub rail and the skegs. If those are good, the rest of the boat will be too.
[img][/img]
GO4BROKE is offline
Old 03-04-2009 | 09:33 PM
  #38
Jim Diesel's Avatar
"Unregistered Gun"
Well installed the new insert today after I used acetone on the holder sanded the scratches out and buffed the holder. It looks great but it kicked my butt. Dont try and do it by yourself it sucks...
Old 03-04-2009 | 10:18 PM
  #39
Plum_Crazy's Avatar
Yea, it definitely sucks. But, I didn't want to tell you that before you started.
Old 03-06-2009 | 01:00 PM
  #40
GO4BROKE's Avatar
Yup, it sucks. I had the wife help hold it.
[img][/img]
GO4BROKE is offline
