Just Turbines
Old 11-15-2013 | 02:52 PM
  #111
KNOT-RIGHT's Avatar
here some more[IMG][/IMG]
KNOT-RIGHT is offline
Old 11-15-2013 | 02:53 PM
  #112
KNOT-RIGHT's Avatar
[IMG][/IMG]
Old 11-15-2013 | 02:58 PM
  #113
KNOT-RIGHT's Avatar
The same fuel control is used on the 13b as the 703 models
1480hp 1800hp respectively.
Old 11-15-2013 | 03:19 PM
  #114
KNOT-RIGHT's Avatar
here are the fuel rails. I am sending these to Jim to check pattern and flow
[IMG][/IMG]
Old 11-15-2013 | 03:24 PM
  #115
KNOT-RIGHT's Avatar
there is a center orifice. Primary fuel starts flowing 8-12%N1
Secondary comes in with the primary around 32% and a outside and also combuster air is mixed into the very outer perimeter.
Old 11-15-2013 | 03:31 PM
  #116
KNOT-RIGHT's Avatar
Note: the fuel flow to these is all deter mend by varying the pressure once n1 sees 32% both primary and secondary
are flowing. The fuel control only varies the pressure to these nozzles.
No duration or pulse only pressure.
So in theory you could throttle the engine with a gate valve.
Old 11-15-2013 | 04:43 PM
  #117
1 MAIDEN AMERICA's Avatar
Is that a tub o vasoline next to the repair order? Why you're doing this yourself this time?
Pics/story are awesome!
1 MAIDEN AMERICA is offline
Old 11-15-2013 | 04:46 PM
  #118
Wow....you must be an faa certified technician....this is some really high tech stuff....l own an auto repair facility. ..and am an ase certified master technician...so l can tell when someone is truly knowledgeable in a particular field..hats off to you sir...thank you for taking the time to show us minions what it takes to truly be dedicated to your hobby
trouble maker ll is offline
Old 11-15-2013 | 08:25 PM
  #119
This thread is as assommume as it gets. Please appreciate all off the dynamics G. has offered up! JJBGOOD
I'CE is offline
Old 11-15-2013 | 08:27 PM
  #120
:Weston and Evan likes vry much
I'CE is offline
