Just Turbines
Old 01-13-2014 | 06:55 PM
  #331
KNOT-RIGHT's Avatar
install the Teflon o rings
KNOT-RIGHT is offline
Old 01-13-2014 | 06:58 PM
  #332
KNOT-RIGHT's Avatar
here is the data PPS provided on the flow rates
Old 01-13-2014 | 07:02 PM
  #333
KNOT-RIGHT's Avatar
Here they are installed and torqued to 80 inch lbs
Old 01-15-2014 | 02:48 PM
  #334
KNOT-RIGHT's Avatar
A close look at the failed fuel atomizers
The more i get into this the more i realize that even though the hours are low on these engines
after 5 years running it was a good thing to take them apart for inspection.
Look at the shroud this would have eventually found its way right into the first GP rotor.
Old 01-15-2014 | 02:49 PM
  #335
KNOT-RIGHT's Avatar
see the crack
Old 01-15-2014 | 02:51 PM
  #336
is this one already missing a chunk of metal?
pstorti is offline
Old 01-15-2014 | 02:54 PM
  #337
KNOT-RIGHT's Avatar
the shroud is about to let loose
Old 01-15-2014 | 03:51 PM
  #338
KNOT-RIGHT's Avatar
yes sir
Old 01-15-2014 | 05:38 PM
  #339
it made it out of there without messing anything up i guess?
pstorti is offline
Old 01-15-2014 | 06:39 PM
  #340
Gerry.....I'm officially going to call you Dr. Arata with a PHD in Internal Combustion!....Did someone say Test Ride in the late Spring.
OLD MAN is offline
