Just Turbines
Old 11-12-2013 | 06:01 PM
  #61
its amazing to see the inner complexity of those things. Thanks for detailing this!
phragle is offline
Old 11-12-2013 | 07:08 PM
  #62
Is the manufacturer concerned about SCC (stress corrosion cracking) in inlet section dovetails where salt is evident?
Amazing they hold up for 5 years in that environment...
thanks for posting..
Lane
28 V is offline
Old 11-13-2013 | 02:13 PM
  #63
KNOT-RIGHT's Avatar
Lane
im not sure it was corrosion. My guess heat. Here are some shots of the other side of the
nozzle
[IMG][/IMG]
KNOT-RIGHT is offline
Old 11-13-2013 | 02:19 PM
  #64
KNOT-RIGHT's Avatar
Jim is sending me some tig rod that is designed for this
i would think it would be something similar to this.
High-Performance Nickel Alloy X TIG Welding Rod. ERNiCrMo-2
TIG welding rod. AWS: A5.14-89 grade. Class: ERNiCrMo-2 SAE-
AMS 5798D.
Here is another crack. This is a stationary component but if left in its currentstate my assumption would be eventual contact or
rubbing against the rotor which sees 22,000 rpm.
[IMG][/IMG]
Old 11-13-2013 | 02:42 PM
  #65
KNOT-RIGHT's Avatar
ok while we are waiting on Tig rods and special pullers to remove the Gas producer nozzles and rotors. lets go from this
side...........[IMG][/IMG]
Old 11-13-2013 | 02:45 PM
  #66
KNOT-RIGHT's Avatar
to this side.
This is where the planetary s and gear reduction takes place it takes the 22,000 rpm of the N2 system
down to 6600rpm.
I will attempt to pull this cover off and see whats inside.[IMG][/IMG]
Old 11-13-2013 | 03:18 PM
  #67
KNOT-RIGHT's Avatar
this stuff[IMG][/IMG]
Old 11-13-2013 | 04:57 PM
  #68
Knot-Right :This is a GREAT thread... just as your install into the Skater was!!! Like the fact that you explain each step with a detailed photo.
Out of curosity, what would a recognized shop charge for a full teardown,inspection, reassembly (obviously not for flight status) for a T53 - any idea roughly before necessary parts added to repair costs?
speicher lane is offline
Old 11-13-2013 | 05:56 PM
  #69
cougarman's Avatar
Nice thread Jerry,........... Geeeesh I think your worse than me for the projects ;-)
Jon
cougarman is offline
Old 11-13-2013 | 06:36 PM
  #70
Wow thats amazing! Thanx for sharing!
ICDEDPPL is offline
