Thad Allen's Apache + The Birth of the Cheetah Cat >
Old 05-08-2010 | 04:02 PM
  #101
Steve 1's Avatar
Here is the T-4 Console being CNCed at Marine concepts it is high density urethane foam and was a very stable piece.
Attached Thumbnails Thad Allen's Apache + The Birth of the Cheetah Cat-consolecnc.jpg
Steve 1 is offline
Old 05-08-2010 | 04:06 PM
  #102
Steve 1's Avatar
Back to some T-4 setup Shooting in the Beams.
Steve 1 is offline
Old 05-08-2010 | 04:12 PM
  #103
Steve 1's Avatar
I Beams are in place here under the shadow of the eventual T-4 , I just use cheap white latex wall paint in the top flange it holds my layout very well. Nothing is more important at this stage than the base that will support all this work to be 100% level and true and Strong!
Steve 1 is offline
Old 05-08-2010 | 04:14 PM
  #104
Steve 1's Avatar
Setting plywood frames
Steve 1 is offline
Old 05-08-2010 | 04:17 PM
  #105
Steve 1's Avatar
Frames are in place thanks to a good center line and we always notch the keel in to lock the frames in place.
Steve 1 is offline
Old 05-08-2010 | 04:19 PM
  #106
Steve 1's Avatar
Frames are in place I wrapped a temporary long foam plank down the length to provide more stability.
Steve 1 is offline
Old 05-08-2010 | 04:21 PM
  #107
Steve 1's Avatar
Here is a trick cutting along the Chine a wormdrive skill saw has the right blade speed for this foam it will not smear the blade then load and kick back, I use a Batten as the guide and the angle error as the sides go in I just hold the saw horizontal a tiny bit.
Steve 1 is offline
Old 05-08-2010 | 04:24 PM
  #108
Steve 1's Avatar
Transom framing I put a piece of 4" I beam along the bottom to keep it straight
Steve 1 is offline
Old 05-08-2010 | 04:26 PM
  #109
Steve 1's Avatar
Chines cut in and finished.
Steve 1 is offline
Old 05-08-2010 | 04:28 PM
  #110
Steve 1's Avatar
Earlier in the Thread I mentioned a Table here is a picture of it simply done, there were two 3 Hp Routers mounted to the underside on a piece of 1" MDF
one had a 1" box cove bit and one had a 1' bead bit which is the one I am showing here.
This processed all the plank material for the T-4.
Steve 1 is offline
