Thad Allen's Apache + The Birth of the Cheetah Cat >
Old 05-17-2010 | 08:59 PM
  #421
Steve 1's Avatar
Dave my experience has been when bedding full sheets, the bleeder holes need to be @ every 3" across the panel and if using a ester resin, I would use corebond as it has a phenolic flake as a filler thus giving great shear resistance, and Bag using the 1/2" bubble pack bubbles down to allow space for extra adhesive and priming resin to migrate from the bond line to the top and the core, You want 1 MM of bondline., Priming resin is a must and is part of the corebond’s curing/bonding process , I roll it on then squeegee the excess you want a wet surface but not flooded with the resin. Do a test.
Steve 1 is offline
Old 05-17-2010 | 09:17 PM
  #422
glassdave's Avatar
Neno the mind boggler
Thanks Steve, good stuff. I suppose my thoughts were based on more traditional mid range foam cores and not with a dynamic core. It makes sense to not disturb the physicals when thinking about it that way.
08 OPA High Points Champion
glassdave is offline
Old 05-17-2010 | 09:19 PM
  #423
Steve 1's Avatar
Dave we would have made a good team Sir as you can think!!
Steve 1 is offline
Old 05-17-2010 | 09:29 PM
  #424
How was mine built? I have a project I'm thinking about using foam in...
POWERPLAY J is offline
Old 05-17-2010 | 10:04 PM
  #425
Steve 1's Avatar
What do you have?
Steve 1 is offline
Old 05-17-2010 | 10:06 PM
  #426
95 sportdeck
Old 05-17-2010 | 10:17 PM
  #427
Steve 1's Avatar
95 sportdeck
They were doing some bagging yours has a divinnycell cored deck,I was overseas then but that was the system they were using,I came back in 2001 for the 38 tooling and then Corecell was used. Now any sheet core "must" be bagged into place as weights and ETC will not work period.you just move the air around. Let me know what you want to do and maybe I can steer you in the right direction.
Steve 1 is offline
Old 05-17-2010 | 10:21 PM
  #428
Old 05-18-2010 | 08:34 AM
  #429
Steve 1's Avatar
This is a good job of Core Bonding,you can see material came out of every bleeder hole in the Corecell up on the Port side
Steve 1 is offline
Old 05-18-2010 | 10:27 AM
  #430
glassdave's Avatar
Well thank you Steve. Ya never know, maybe we just might still someday.
