Just Turbines
Old 12-06-2013 | 05:11 PM
  #231
1 MAIDEN AMERICA's Avatar
BEAUTIFUL!
It looks like an oil schematic for an old Hydramatic,with pics of linkage and everything.
Take a look at a schematic for today's 6sp autos. They're like those old 3D pics that when you stare at them long enough something pops out.
Do modern day turbines get rid of some of the linkages and valves with electronic solenoids and actuators?
1 MAIDEN AMERICA is offline
Old 12-06-2013 | 06:26 PM
  #232
KNOT-RIGHT's Avatar
Thats exactly what i thought when i saw it for the first time. However it really is a reliable unit if you look you will see it has a
emergency fuel selector in the event it fails.
it has some inputs incoming air temp, barometric pressure for altitude, rpm input. Compressor pressure.
ouputs are inlet vane guides bleed band and plotting fuel schedules for acceleration and deceleration.
as stated earlier the modulation of the fuel output is really only pressure.
this unit could be replaced by any motec unit or equivalent.
KNOT-RIGHT is offline
Old 12-06-2013 | 08:22 PM
  #233
WildThing47's Avatar
Gerry, always cool stuff always a good read!
WildThing47 is offline
Old 12-06-2013 | 11:04 PM
  #234
i just have one observation. 2 turboprop motors in a 46 skater...in the boating on a budget section!?!?!?
dereknkathy is offline
Old 12-06-2013 | 11:28 PM
  #235
i looked but i could not find[ small budget] in the title.
mike tkach is offline
Old 12-07-2013 | 06:31 AM
  #236
Originally Posted by KNOT-RIGHT
Now that you cannot keep mercury sixes on the boat because you should have used Arnesons or Bpms in the first place.
If you would like to try to blowup these Arnesons or bpms
Try turning this screw its item 10 on the schematic it turns the fuel pressure and flow way up be careful because it does not adjust
any other wonderful little things that fuel control is doing.
here is what the destroyer knob looks like. Again you have been warned it shows no Mercy!
did you hire a chimp to do the safety wiring??? Very tempting I bet to mess with those settings just a little.
pstorti is offline
Old 12-07-2013 | 09:31 AM
  #237
KNOT-RIGHT's Avatar
Good to hear from you Pat I look forward to are next poker run.
Send some warm weather up here From Blue Octane Marine Group!!!!!!!!!!
Old 12-07-2013 | 09:37 AM
  #238
KNOT-RIGHT's Avatar
10 years ago i was showing how to boost reference carbs in the tech section
Which i considered putting this.Honestly I really did not know where to post this.
Are you a Aviator? by your reference I am guessing.
Old 12-07-2013 | 09:44 AM
  #239
DIY works. Carry on.
Old 12-07-2013 | 09:47 AM
  #240
KNOT-RIGHT's Avatar
Yes these will be tweaked after the upgrades. The thermal limit is what we are concerned with. I would be lying if i said i did not.
