Just Turbines
Old 06-04-2020 | 12:46 PM
  #651
No aerators on mine but remember I have 1.19 reduction so my prop torque will be greater than yours if you're at 1-1 did you ever check your reduction to see if that's what they are If so you might need them but it all depends on what props you run.
I am 16.5 x 38 at present
My boat weighed in at 6700kgs with two full tanks of fuel, haven't run it up yet still tinkering with cameras, new batteries, and a few cosmetics as well as going over to a fully digital dash with a gateway to convert Racepak VNET to NMEA2000.
999JAY is offline
Old 06-04-2020 | 01:12 PM
  #652
KNOT-RIGHT's Avatar
that boat is off the charts!!!!
well if you are -2 degrees negative also fully trimed up then im staying right where i am
I feel like im at the black jack table in l las Vegas and i just drew a Ace and a King. Im Staying!!!!!
So if i may give all you people out there running Turbines some Advice.
Listen to your Coast down very carefully for any strange noises.....
I mean when you shut it down listen to any rubs or sound and get to know how they sound..
Jim at PPS taught me that years ago!!!!!!!!!!!!!!!
your ears are your friend. Except if you are with my ex wife!
KNOT-RIGHT is offline
Old 06-04-2020 | 01:25 PM
  #653
KNOT-RIGHT's Avatar
999 Jay please post a video when you get her wet!!!!
here is nice and easy fly by
Cruising by Famous Outrageous 33 Sutphen!!!!
Sorry i know all you guys wana see a Scary Fast Sticks pinned with my foot Jim Lee style doing 200 plus
its all i got right now!!!!
Stay tuned!!!!!!!!!
Old 06-04-2020 | 01:51 PM
  #654
She's in the UK at present and heading to Florida next year that will be the first time I will get a chance to get her wet.
Were I am in the UK there are no good boating areas and the roads are to narrow to transport a boat like this on a regulars basis not to mention all the do-gooders that have imposed a 5mph speed limit on all the lakes and waterways YES that right even in the Lake District were Donald Campbell broke the water speed record they have killed boating off!
Let see if this works this was the boat last year.
https://photos.app.goo.gl/w7kFx53pkuhffzFW6
999JAY is offline
Old 06-04-2020 | 04:16 PM
  #655
KNOT-RIGHT's Avatar
Originally Posted by green lightning
At this point I would say try what you got . is it possible to remove any material from the bottle jack mounting flange if you can't get the trim angle you need ?
yes i think thats the ticket. I did look into removing material from flange however the socket allens holding it up are recessed not allowing much material off.
Old 06-04-2020 | 05:39 PM
  #656
The above boat back in Her earlier Glory and life ..
I'CE is offline
Old 06-04-2020 | 06:02 PM
  #657
WOW, 999Jay what a fantastic looking boat. I believe you boat spent some time in Connecticut a few years back. Been working with Knot Right on the BPM project. We did a test to determine his gear ratio and came up with +- 1.25:1 under-driven. Next time, probably this weekend we will test again with a stationary pointer and a degree wheel and then calculate it more precisely. Also I see you are spinning your wheels "in". The Skater with the number 6 drives ran best spinning out and that is how she is currently set up. Might you have any thoughts on rotation?
I'CE is offline
Old 06-04-2020 | 08:50 PM
  #658
Default 47 Ex
Originally Posted by sutphen 30
should you have lowered the whole assembly closer to the bottom of the boat?arneson wanted us to be 3/4" from the bottom when we did the conversion on the 47 excaliber?
Sir William these: Just Turbines-4450695_20130903075052770_1_xlarge.jpg
I'CE is offline
Old 06-05-2020 | 06:45 AM
  #659
KNOT-RIGHT's Avatar
Here is Dave Scotts old Boat that are reconnaissance satellite took some spy photographs of.
these are fixed arnesons note spacers
it does not look to have positive trim eithier
Old 06-05-2020 | 08:33 AM
  #660
Originally Posted by I'CE
Would venture to say as Knot-Right has it rigged it is near spot on, seems he could, only compensate by rising the tail shaft upwards which would possibly correct the angle of attack (propeller angle to the surface) any thoughts? You have the Green and White Fountain with the Arneson's correct?
Yes
green lightning is offline
