View Full Version : Drives and Lower Units
- Drive Slipping?
- Drive alignment: Any TRS experts left out there?
- bravo drive rebuild
- Bravo 3 shift and leaking gear lube
- Bravo One XR Sportmaster ITS - Rotation
- Bravo 1 vs Bravo XR
- 1.36:1 Bravo side water P/U to 1.5:1 with low water P/U
- Torque specification for XR Sportmaster
- Cleaning up TRS
- Going rate for a pair of Imco 1.36 drives?
- Nose Cone Installation On Bravo X1
- Bravo 1 parts
- Why was the Lube fill moved from the side of the drive to the back?
- Konrad Drives
- Bravo 1 question
- How much horsepower can a trs drive take
- 1.5 vs 1.36 and acceleration numbers...
- Drive lube capacities
- Pair of fresh Arneson ASD8's for sale - 16" offset!!
- Gimbal bearing housing broke
- BMax Hex Head Magnetic Vent/Drain Plug for Bravo
- Trim leaking down, need help
- Drive play question
- Need Trs Port Side Prop Shaft
- Bam Cyborg failure??
- B Max 2" shorty lowers
- Arneson question
- Need Bravo XR Uppers
- formula 233 cc alpha or bravo?
- Nose Cone, Proper Attachment, How?
- #6 Drive Drysump ??
- Velvet Drive Transmission
- Alpha Gen II to Gen I ???
- Kaama Surface Drive HELP !
- Anyone moved from a dual prop to a performance single set-up??
- Need TRS Gimbal Ass'y
- What year is this drive
- Xr Drive Question
- Bravo One implosion?
- Bravo 1X vs Diesel Bravo 1X
- steering
- bravo 1 lost forward gear
- BMax questions
- Need a Velvet Drive 72C
- Imco 1000 ?????
- Tempest T-tork Surface Drive? Anyone?
- switched to mobil 1
- New style versus old bravo input shaft.
- trs drives
- Speedmaster drive input to output dimension?
- engine/drive alignment
- flywheel
- Bravo 1 HP
- Bravo gimbal - Imco Extreme SC
- Low Water Pressure
- Installing a TRS?
- No FWD / REV
- Fluid Capacity of Speedmaster II
- Blasting Material
- What's the difference?
- uneven drives
- Please HELP
- N/A vs. blown vs. drive life
- Best Drive for high power heavy 27' application??
- Drive Swap RH to LH
- Looking for Bravo gears
- Bravo upper
- Need hydraulic steering for TRS or Bravo
- Bravo Spacers
- bravo 1 rotation on 1990 300ES
- Will an Alpha 1 hold up in a 21' deck boat?
- TRS Needs Face Lift
- Prop shaft tolerances
- seized prop...
- Stronger LH or RH TRS
- TRS lower case
- X-dimension help...Need shorty lower???
- Who uses what oil in their drives??
- Exhaust on Bravo and TRS
- Drive Showers not Showering
- What is the deferents
- What is the Best X Dimension for 28 Magic Deckboat
- Drive Saver, for Stellings ext box, from Teague
- ?? What are the drive spacers for Bravo's
- Silver XR's?
- Water drip from lower unit.... am I being paranoid?
- water pick up questions, for bravo1
- trs rotation?
- Where to find TRS gimbal bearing (tailstock)
- TRS and Velvet Drive Problems
- TRS Input shaft yoke replacement ??????
- BravoOne or BravoThree? Which is better for Cigarette 35 Hull?
- Bravo 1 gimble question
- #4 drives
- What would cause this?
- Bravo 1 knocking
- Trs Tools
- 3's on ft. myers craigslist
- Looking For A Tool Set For Ssm#4
- I need a set of new or used #6 props ASAP!!!!
- Maintenance costs on dry 6's?????
- need help clearing plugged hole above water pickups
- What's the Trim Limit for TRS Drives?
- Imco shorty
- Extension Box on a Nordic thor Cat
- Losing fluid in upper!!
- looking for a #6 nose cone removal tool
- Bravo drive assembly question
- Water in TRS?
- gimbal rings alpha one gen 1 vrs gen 2
- Can you still use standard Bravo 1 couplers with Bravo XR's
- Drives
- Do bravo x drives require red dot bearings
- Teague ss Bravo upper shower.
- Bravo 1 Lag -2002 496 HO
- Wanted: pair of bravo 1's and transom assemblys
- bravo 1 propels at idle speed only
- TRS Drive Oil
- TRS how do I know when its time to rebuild?
- Wanted: Lower Bravo 1 housing
- Alpha worth ANYTHING???
- Blown on the trailer
- Alpha Gen II Ratio Change
- Alpha/Bravo
- Drive Stuck in Gear -Help!
- Bravo 1 universal joints
- Looking To Trade Pair Of#6 1:50 Uppers For 1:35s
- Drive oil Leak??
- amsoil gear lube turned "milky" after 1 run
- How much HP / outdrives
- Trs
- Tell me about the ASD6 bravo conversion
- First time changing my drive oil
- Aftermarket drive
- Drive setup
- What outdrive
- Stripped vent hole threads
- knock sound
- Just making sure?
- TRS Identification
- Bravo three x: WANTED
- Merc XR II Racing Out Drives
- bravo drive oil what the best.
- B-Max
- Alpha Trim
- Changing Oil In Xr
- TRS Drive Oil
- Xpower Drive Any One Running One
- Max Machine works Drive parts
- trs u-joints
- #4 Drives For Spares??
- Trs
- SSM HP ratings
- Need Alpha Drive
- What gear ratio do i have?
- Trs Drives
- Bravo 1 to Bravo 3 on a sport cruiser
- Bravo1 question
- #6 Gear Sets-1:35
- #6 drives
- Konrad Marine Speedmaster Conversion Special!
- Blackhawk drive - what are they?
- what oil for borg warner??
- TRS in trailer position - engine run ??
- Bravo 2 noisy when hot
- TRS lower questions
- 1991 Bravo One clutch replacement?
- Impact damage
- Gear Ratio Questions
- TRS Questions Please Help
- TRS Rotation Questions
- Replacing Coupler, have a few questions...
- need a drive alignment tool.
- '87 Formula 223LS Problems... Need help!!
- Bravo care!
- TRS Outdrive Shower's
- Leak in my TRS drive is it a do it yourself fix?
- TRS Wont Go Down
- Need A Drive Oil Reservoir
- Looking for Bravo upper gear
- shim
- Replacement Skegs
- HP rating for a Bravo 1
- drive wont go up
- Bravo1 stuck in drive..HELP!!
- Are new gears noisy?
- Lower unit placement? AHH HELP ASSURE ME!!
- Need Bravo 1 drive help ASAP!
- Need Help With #4ssm Drive Height
- How well do u think it would work?
- SCARAB AVS 33' change of PROP from 28P to ???
- looking for complete #5 ssm
- Drive Noise
- bravo 3 , who makes a stronger/better upper
- Indicator issues
- Small water leak thru drive,, Ideas?
- BMAX parts and help
- Who rebuilds bravo drives in michigan
- drive leaking
- Trs Vertical Shaft Dimension
- bravo I drive temp lines
- How much change 1.81 to 1.65?
- #6 drive question
- Used Drive Evaluation Before Purchase?
- Drive actuator
- Bravo drive
- TRS Drive Spacer
- outdrive oil
- Alpha 1 gen 1 w/ 454
- Bravo Drive lube bottle overflow???
- Bravo Drive Mechanic in Delray FL area?
- Shift arm removal on a bravo 1
- Hardin Marine 3 hole steering end cap
- Can I beef up what I have?
- Who Has The Best Deal?
- Gimbel Ring Hole
- Props for #2 Speedmasters
- Pressure Testing a Bravo
- Does anybody make or have a old style drive bottle new?
- TRS drive to thru hull exhaust
- Junk XR gears.
- What's The Max
- Shift-throttle adjusting
- Volvo shift interuptor
- Imco Sc or Teague Platinum
- Bravo one leaking at input shaft...
- #6 Gear Sets-1:35
- bottle location
- Question for Mr Gadgets
- Outdrive oil cooler
- XR Decals?
- Extension Box wanted
- New Imco Shorties
- Which outdrive gears to go with?
- Newer Xz drive with old B1 transom
- Which Pumps??
- Arneson 31 deg. wedge plates
- # 6 lowers
- Stripped threads - top cap bravo 1
- TRS Bellhousing studs
- An old #1 Drive How much power?
- Bravo One Bellows Replacement
- TRS Bearings
- drive repair
- TRS Tilt/Trim cyclinder Leaks
- Help Ssm 4
- Bravo Side Fitting?
- Bravo 3 gimbal replacement
