Just Turbines
Old 03-03-2014 | 10:29 PM
  #451
Originally Posted by KNOT-RIGHT
Jim at PPS sent me the stainless versions of the i think 71 of these.
71-72=73 lol
I'CE is offline
Old 03-03-2014 | 11:19 PM
  #452
Big turbo fans! I would love to see the inside of one.
on these 53,s the starter generator spins n1 (GP) then the fuel is added.
the n2 (PT) is there in the gp path extracting the energy then its shaft runs right thru the hole engine back to the
planetary s reducing it. Thats really the key to being able to use them in a boat,
The trick of being able to stop n2 while the gp is running and select a shift forward .neutral reverse.
I can only imagine the energy on the huge engines on the ignitors
the video i posted does not really show how intense the spark is.
If the FAA showed up at my joint they would lock my A$$ up
10-4 on the safety wiring i have been trying to get it. Dont laugh but i could feel it in my forearms
from the milbars.
always had this ? what lubes if anything the inner shaft to the outer shaft trans version space
I'CE is offline
Old 03-03-2014 | 11:28 PM
  #453
is it air gap only no rub no friction free float support by inner and outer bearings. diagram please if u can
I'CE is offline
Old 03-04-2014 | 07:24 AM
  #454
KNOT-RIGHT's Avatar
Originally Posted by I'CE
71-72=73 lol
that there is a jack screw hole.
KNOT-RIGHT is offline
Old 03-04-2014 | 07:27 AM
  #455
KNOT-RIGHT's Avatar
no lube no contact whatsoever with the comp shaft
yes its free floating supported by the PT assemble then it runs straight thru the compressor shaft resting in the planetary
it has air surrounding it and is also hollowed for cooling
Here is your torque wrench
Old 03-04-2014 | 07:34 AM
  #456
KNOT-RIGHT's Avatar
this locking fixture locks down the pt assembly
so i can torque the hollow bolt
Old 03-04-2014 | 07:37 AM
  #457
KNOT-RIGHT's Avatar
then this
Old 03-04-2014 | 07:43 AM
  #458
KNOT-RIGHT's Avatar
this wraps it up
Old 03-04-2014 | 09:56 AM
  #459
Mission accomplished when do they help with global warming? lol Can you test run them b4 they are rigged?
I'CE is offline
Old 03-04-2014 | 07:33 PM
  #460
KNOT-RIGHT's Avatar
round two
