Just Turbines
Old 05-10-2020 | 02:00 PM
  #561
Originally Posted by KNOT-RIGHT
Peek a boo i see u have no head!!!
Jim at PPS was able to tell me what it was from 1500 miles away with my iphone video!!
Really!!!
ok now i gotta keep going
this is why you do your inspections. Because nobody ever believes a story that starts off with “everything was running fine and all of a sudden it went POP”
JAMESP7453 is offline
Old 05-12-2020 | 04:13 PM
  #562
KNOT-RIGHT's Avatar
Ok here you go Install diffuser Install seal retainer
Install roller bearing Install three new crush seals
Carefully install bearing retainer Pinch plate assembly Take note on oil feed and return oil Holes match up Gently tighten the two flathead Screws
Install the cone and seal taking note On shims
KNOT-RIGHT is offline
Old 05-12-2020 | 06:08 PM
  #563
KNOT-RIGHT's Avatar
The impeller bolts 160 in. Lbs. rear shaft 200 in. Lbs
Now install deflector and first gp nozzle
then install the louvered sealing disc
Old 05-12-2020 | 06:19 PM
  #564
KNOT-RIGHT's Avatar
165 inch lbs on the 6 bolts Holding deflector
and gp nozzle
110 inch lbs on louvered sealing disc
Old 05-13-2020 | 06:43 AM
  #565
KNOT-RIGHT's Avatar
Backing up
when installing the two gp rotors
install them 180 degrees from the
compressor heavy marks
Rotor heavy marks 180 out from compressor
Compressor heavy mark
Old 05-13-2020 | 06:45 AM
  #566
KNOT-RIGHT's Avatar
Its kinda hard to believe that those marks
are still there from 2007
thats not done with a crayon
Old 05-13-2020 | 07:33 AM
  #567
Knot--Right
I have just entered the turbine and rudder boat world with my new boat T53 703s had a little experience previously with turbines but this is another level.
Love your thread might be very handy in the future if I need to do any work.
What's your thoughts on compressor wash distilled water and what solution?
999JAY is offline
Old 05-13-2020 | 08:52 AM
  #568
Originally Posted by 999JAY
Knot--Right
Sorry for the derail Knot-Right but 999JAY, what boat did you pick up?
speicher lane is offline
Old 05-13-2020 | 09:07 AM
  #569
KNOT-RIGHT's Avatar
Knot--Right
yes distilled water is great idea as you know it will want to pull any minerals or deposits I have run 50 distilled and 50
value craft (autozone) washer fluid. It will add about a 100 horsepower boost you can actually watch your egts drop!
Old 05-13-2020 | 09:09 AM
  #570
KNOT-RIGHT's Avatar
Thumbs up
Yes!!!!!!!!!!!!!!!!!!! 999Jay Please tell us and post some Pics!!!!
