Just Turbines
Old 06-05-2020 | 01:40 PM
  #661
Originally Posted by KNOT-RIGHT
Here is Dave Scotts old Boat that are reconnaissance satellite took some spy photographs of.
these are fixed arnesons note spacers
it does not look to have positive trim eithier
Another Shot courtesy of Tim Sharkey
and once transferred to Rick Merola G3 Just Turbines-0189.jpgJust Turbines-0232.jpg
I'CE is offline
Old 06-05-2020 | 01:51 PM
  #662
we can also take note; in the image as Bacardi Silver the wheels are spinning out, same as KR is set up
I'CE is offline
Old 06-06-2020 | 10:47 AM
  #663
ICE mine seems to be set up spinning in.
999JAY is offline
Old 06-08-2020 | 05:17 PM
  #664
KNOT-RIGHT's Avatar
Here is the first start of the motor i had to dismantle and install new impella Bolts
notice the long spool
KNOT-RIGHT is offline
Old 06-08-2020 | 05:23 PM
  #665
KNOT-RIGHT's Avatar
Here is the starboard with some shifting
on the trailer.
what happens is the n2 which is coupled to
the shaft drive wants to go up in rpm and try to
match n1 with no load so essentially putting
a higher load on the brake and caliper assemblie then if you were propped and
moving around the Docks
Old 06-09-2020 | 06:47 AM
  #666
resurrected's Avatar
Oh that is awesome!
Thank you, I need some time alone now......
resurrected is offline
Old 06-09-2020 | 09:17 AM
  #667
Knot-Right can the N2 brake be left off without a load on the prop shaft if so will the N2 stay within its governed limits
999JAY is offline
Old 06-09-2020 | 09:21 AM
  #668
Curious to find out how it performs compared to the #6 one thing for sure maintenance should be a lot less costly
999JAY is offline
Old 06-09-2020 | 12:15 PM
  #669
YES you are. I had mentioned that a few posts back (#657). We have the gear ratio figured out, 5 revolutions of the inside drive shaft to 4 of the outside prop shaft thus 1.25:1. thank you
I'CE is offline
Old 06-10-2020 | 07:09 PM
  #670
KNOT-RIGHT's Avatar
Yes it will sit about the same as n1
u can atually increase n1 on the trailer and
watch n2 climb it climbs pretty quick.
i have my n1 set at 52 percent at idle.
n2 govenor or droop compensator is safety
wired wide open.
im pretty sure thats how arruda did it aswell.
can u see your n2 quadrant?
otherwise u would need two throttles or
some type of linear actuator found in a helicopter
