View Full Version : Swap Shop
- looking for mercuiser 7.4 flame arestor/cover
- Looking for 24 Hydromotive LH
- FS: BBC Corsa Electric "Captains Call" Exhaust Diverter System
- 420 HP 454's
- 496 heads
- (2) Gen IV 454 Mags under 150 hours - 1989 models
- Wingplate
- 29 2001 repo no motor $12500
- 575SC Blower Belts
- Alpha Bell housing $50 Ea
- Hydromotive R&L QIV 24 $500
- ITS/XR Drives
- 23P Mirage Plus RH Prop $300 or trade?
- (2) Thunderbolt distributors
- Stelling Stand Off Box
- Imco Gimbal Housing
- Merc Bulldog 540 short blocks
- Crossover For Bbc
- BBC dart intake - oval port
- b&m 250 crank pulleys and 1000cfm 4150 carb
- BMW 550 Wheel
- Cheap Parts
- 22p prop for Bravo 1 for sale or trade
- Oil dipstick
- 16.5x29 3 blade small shaft props
- CMI sport tubes, 2 pairs
- Bunch of parts. Any takers?
- DANA marine power hinges
- WTT: CMI tail pipes for single engine cat
- Bravo Xr, Rear Cap
- Stainless hardware
- Engine mounts
- Hardin marine 2 price valve covers
- Left hand props
- HERING props - 31p - 5 blades - IMCO
- chevy dually
- 55 Foot Slip at Rivierra Dunes in Palmetto, FL *$400/Month*
- -2 XR Sportmaster lower w/accesories
- thunderbolt boxes
- thunderbolt boxes
- thunderbolt boxes
- Wtb. 280 S Tabs..bravo Propps..steering Parts
- What is a Maserati sign worth?
- waterproof stereo/radio housing
- IMCO twin ram hydraulic steering
- 496 risers
- Mercury angled cable thru hulls
- two new 1071 blowers
- 525sc,s
- SensaTrac Shocks for 2wd Silverado/Sierra
- 502 Mpi Parts
- MEFI 4 ECM - Delphi
- HP500EFI & HP500 Mercury Racing blue sepentine pulleys
- 16 je blower pistions 4.604
- Bravo 1 Prop
- 35' cigarette mistress hull $2500
- many parts
- Wtt. m1 pro charger for stainless marine exhaust
- Bilgekote
- Perko sea strainers
- Speedmaster 3 4 5 trim indicators
- Thru hull cable fitting
- Thru hull water pickups
- bilge vents
- Gauge bezels
- Faria tachs with hour meters
- Driveshafts
- Forward engine plates
- Transmission oil thermostats
- #6 ssm props with hard cases
- 496 HO for sale
- Garmin Marine Handheld GPS 72
- SR-1 Props
- 44'-46' Alum Trailer - $6800.00
- Pro charger belt tensioners +plates
- 1958 Whirlwind 14-ft Super Deluxe w/ 1958 35-HP Johnson (RDE-19C)
- WTB cast iron Gentry Turbo Exhst housings
- starter for 502 hp500
- Mayfair Dual Ram Setup with Misc Hardware
- 1990 26 Profile
- 1997 Volvo SX drive new in box 1.50 ratio
- Mazco HP4 23p for sale
- Remote filter mount
- Power Steering Cooler
- 496 exhaust
- Stock 502 Oil cooler/ PS cooler combo
- imco lowers
- Dart 308 Marine Heads & other
- Three Bank Pro Charger - 10 amps per bank
- Mercruiser Bravo Trim Reservoir Caps New OEM
- Gil big block exhaust
- MerCruiser Bravo XR Sweptback complete
- 502 575 H.P. EFI Complete
- 540 Tall Deck Complete
- 400hr 330 complete
- Ritchie in dash gauge compass
- P/S control valve for HYD steering
- Bravo 1 24 prop
- powermaster marine alternator
- Garmin Inland lakes chip, Garmin Transducer, Boat netting
- 2 1/16" Red Rim "Fountain" gauge blank
- Gaffrig Gauge Bezels 13 of them
- Stainless marine short risers
- Warlock Euro 24' Project
- (2) Bravo I drives 1.50 ratio
- Bam 1450 like new under 10 hours
- Bmax Complete Upper
- 17x 28 3 blade cleavers
- 41 apache race hull
- trs wing plates
- gauges gaffrig
- Bravo 1 Gimbles
- billet front moumts
- 99' HP500 Ignition Parts (2 Sets)
- Bravo 1 Left Drive $2200
- Boat Magazines (FREE)
- Ssm3 drives and gimbles, clean, low hours
- drive special tools
- ebay stainless risers
- air pump for muffers
- trs drives and gimbles complete take outs
- Brand New HIGH FLOW Mercury Racing Sea Strainer
- 525sc Gen VI 516ci, 0 hours hours since refresh
- 48" tunnel tab
- blue hp 500 acc brackets alt pullys
- 1 set corsa silent choice,454 mag carbs set of 23p props cheap
- 280 K-Planes (plates only)
- Rex Marine battery boxes
- (2) Dual Stage Raw Water Pumps with brackets and pulleys
- Merc fuel cooler part#861156A02
- WTB - HP 500 Accessories
- Spare blower belt
- 502 hp500 oil coolers
- 22ft trailer
- Teague oil pan, pump, pickup, dipstick, gasket
- Trim Pump with plastic Res bottle
- Sea Water Pump Gen IV and crank Pulley
- Remote Oil Filter with cooler
- new rolla propellers arneson surfacedrive speedmaster bravo
- marine expanding Foam, kevlar, awlgrip, nomex honeycomb, ultraleather foam backed
- New cruisair 110v 60hz 16000 btu
- new cmi custom long tube headers!!
- arneson asd6 or 1721 drive
- BBC cross overs and t-stat connection
- 2-454 gen 6 short block
- 496 mag 105 hours.
- 454s Complete
- 489 ci 500 hp
- Baja 252 Islander - Windshield pass. side
- Merc BBC 496 Exhaust manifolds & risers
- Gen V Valve covers
- 21 eliminator cat
- Mercruiser Bravo 1 replacement skeg
- Lavorsi white water presure gauges & 420 crank
- FS: New Mercruiser Trim Sender Kit Limit Alpha Bravo
- Formula Fastec Rear Drink Door
- Crane Gold Roller Rockers
- Crane 1.7 Roller Rockers
- '86 Scarab III hull
- Formula 272 bolster actuator...anyone want it?
- latham stering and mercury 280 trim tabs
- 2010 Camaro 19's wheel & Perrili's
- OE Mercruiser Flame Arrestor off of a GenVI 502 mpi
- OE BBC Mercruiser Manifolds and Risers
- FS: CORSA Electric "Captains Call" Exhaust Diverter Systems- 7.4L - 8.2L - $500 obo
- Blower cams, lifters & springs
- 500 efi for sale
- TRS Pumps
- Bravo Couplers
- Bravo Drive Coupler
- 650sc 10hrs
- Trim Tabs
- 540 long block for sale
- WTB: merc 6.2L risers
- #5 drives
- edlebrock 750 carb
- one air pump for muffers
- 23p 3 blade props
- 2 corsa complete silent choice sets cash or trade
- pair of 1050 dominators
- #5 stuff
- miniature snap on tool box NEW
- Merc Racing 525 Heat Exchanger/ Oil Cooler Tank and Hoses
- 454 Mag Carb
- BBC parts Gen 6
- Lifeline Jackets
- 28 bravo 1
- merc racing hp525-850sci short block
- New Volvo DPX Drive assy package
- 2006 37 Active Thunder with 525's (Project Boat)
- merc starters
- bellhousing
- Hydomotive P5-X's
- Bravo 1 dwp lower
- 2 IMCO Nose Cones and 1 Throttle/Shifter Trim piece
- two trs drives for parts
- wing plates trs
- Littlefield Blowers
- Bravo wing plates
- Gen 5 BBC
- Rods,Pistons,Rockers,Gauges
- 454 short block or complete
- 4" s pipes
- mirage propellers
- 525 valve covers
- mc cloud power bolster seats
- teague sea strainers
- aftermarket coolant overflow bottle 30bucks
- bbc 496
- 4" straight exhaust tips with internal flappers
- carter electric fuel pumps
- Bravo 1 Prop
- 2007 496 HO's Factory Sealed
- Speed master #4s
- Huber 1350
- 27' race hull & trailer
- New Holley 850
- SSM 3A & SSM 5 upper gearset.
- xr drives
- 30 Velocity 1600 HP
- 30' Velocity 1600 HP
- Kiekhaffer twin throttle/shifter
- Boats gone, tow rig on ebay
- Bmax, 598BB turn key, HP gimbal assy...$14.5k for all
- Blower, fuel & oil belts
- *** Brand New B&M 250 Blower ***
- Mercruiser Y pipes
- 2000 Warlock 27 world class
- 1992 merc 454 330hp
- NOS,GM,Bowtie Block ,Tall Deck Block #14044808
- Transmissions
- 2001 30 Lightning/Spectre Hull Project
- Pair Merc 300 Promax For Sale
- Trim Indicators for twins
- Two Mk IV Stroker BBC 496's- Short or Long
- Looking For Aluminum Cat Trailer
- TRS Drives Complete
- trs upper, tail stocks, exhaust tips
- small shift props four blade labed
- 5 trim pumps
- BBC JE pistons NIB 4.470 bore dome forged
- 91 270 Baja -$6500
- Looking for lines
- Callies Stealth 4.5 stk. BBC crankshaft
- Crower 6.385 BBC connecting rods
- 509 complete ready to run
- Revolution Marine exhaust
- camshaft
