View Full Version : Swap Shop
- Cigarette Top Gun Rear Bench Seat
- Free Cigarette Rear Boat Seat
- Hardin Marine offshore oil pan 10 Qt. BBC
- Masterlube prelubers
- Stainless Marine exhaust BBC
- Mahle BBC Pistons Mahle BBC270500F03 BB-Chevy PowerPak Piston Kit New in BOX
- BBC Starter
- 2 sets bravo 1'' drive spacers
- Cigarette Racing jacket
- Blue water drive and flap indicator
- Pair of TRS Drives less than 20hrs.
- Set of 26 brovo props
- Bravo XR drive yokes
- gm 14096188 cyl. heads
- Two sets of 088 heads off of my 502
- 16-3/4 X 34 Merc 4 Blade's Like New
- b blades blasters for sale
- 25p Mercury Mirage Prop Labed $300 shipped
- Full cover for 36 spectre PR
- Set of Bravo 1 props. Fresh lab by B Blades. 26' pitch
- 38 fountain drop in carpit
- 454 mpi intake and M1 pro charger GA
- power steering bracket for high performance exhaust
- Stainless Marine intercooler sea strainers
- Bravo HP gimbal complete with inner transom plate
- Kiekhaefer Zero effort throttles and shifters
- BAM 900 trans
- Altrenators, NGK Plugs, Silent Choice, Gen VI 502 Pistons, Gen VI 502 Oil Pan sale
- trs drives
- Pair of 27 P Cutting Edge 5 blade props
- Not mine....42 fountain for auction
- 30p bravo 1
- 454 MAG MPI intake complete with harness, M1 Procharger complete for 454/502 MAG MPI
- almost as new as possible 1050 dominator holly carbs
- Pair of 525efi motors - $9,950 each!!!
- BRAVO 1 22P Left Hand
- TRS drive, gimbal and transom assy
- Marine Machine throttles and shifters
- Aluminum fender holders
- Parting Out Magnum Sedan
- Hardin Marine 1-1/4"NPT Swirl-Away Sea Strainer With Built-In Fluid Cooler
- USED / Rock River Arms LAR-15 AR / Monroe, MI
- Sower power cord and adaptor
- Bravo 1 36p Props
- Latham Steering
- SL 4 - 4 Blade 15.125" Diameter - 24 Pitch RON HILL propeller like a Bravo one
- VDO Gauge set and rocker switches- carling
- 454 / 7.4L MPI Mercruiser, 109 orig hours, complete drop in, freshwater $5000
- New merc 700 and 525 long blocks
- Props, Steering Wheels and More
- Stainless marine bbc crossover set x 2
- Quicksilver 21p prop
- Blower Engine Short Block Aassembly
- Mirage and Tempest Plus props, nose cone, drive spacer and plug wires
- 1 set GIL/MerCruiser polished tail pipes 4" HP500 NEW
- 2 sets of CMI polished BBC Split tops. NEW, never installed.
- 23P Mirage props RH/LH
- 3208 exhaust manifolds
- 30p lab Bravo1 LH&RH
- 525 hp long block for sale
- Fresh 500 EFI for sale
- TRS Drive for sale $1500
- Make Offer Bravo Two lowers
- Bbc drake manifold headers & gil dry tailpipes
- hydeomotive 30p p5x props new
- Custom Motor Mounts
- HPI Baja 5T new build.
- Gil exhaust with silent choice complete twin setup
- imco hyd steering helm post
- (2) livorsi 4 5/8 Mega Rim platinum faces new in the box. $250 for the pair.
- Mercury racing 280 k-plane trim tabs $1250 like new
- Forged eagle crank 454
- (2) 525 EFI INTAKES WITH HARNESS AND FUEL RAILS. $2000 for both.
- Pair of 26 pitch 4 blade bravo 1 props
- BBC parts
- Imco vertical shafts
- Tach adapters, tachs, tips, Cmi hoses, fountain lights
- BBC PARTS 3 grove pulleys, exhaust trim rings. water pump hose.
- BBC parts 2 oil- power steering coolers
- Mecury Maximus 24 Pitch L & R
- hydromotive Q1v 23 p lefty 4 blade
- 2 pair of 088 heads low hours
- SSM big shaft props
- 2 new mercury marine w/p body impeller kits
- Rule 2000 GPH bilge pump new
- 2 brovo three drives with props
- Mooring cover for Baja 275 or Checkmate ZT275
- Complete Bravo One setup for sale
- Mercury Racing 525SC Super Charger
- TRS Tie Bar Saddles
- water neck
- Oil Coolers - For sale
- Brand New 31 P5X's ... Hydromotives
- 509 Short Deck 684HP, 622TQ
- Mercruiser thunderbolt IV Ignition Module V-6 14 used
- Mercruiser thunderbolt IV Ignition Module V-8 24 Brand new
- Formula custom pendents
- Rev 4 23 P RH - $235
- 2-Bravo hp transom assembly's for sale.
- Bravo XR Outdrive Low Water Pickup Just REDONE
- F/S: Whipple Supercharger for Truck
- two 1071 blowers
- IMCO -1 lower for sale or trade for -2
- Bravo Transom
- Marinco 30 Amp 125 V
- Merc Pressure Relief Valve
- Cleaning House - Make Offer
- Mercathode Kit Complete Part# 88334A2
- Project Taylor LP
- Blue vents (bling)!
- Bravo 1 24p 4 blade left rotation F/S F/T
- Isotta Steering Wheel Center Cap
- Aed holley 750 blower carbs (set of two)
- Mercury Bravo XR Uppers
- (4) Gaffrig 4.5" mufflers, $550
- 525 aluminum Cyl heads 40 hours
- Mercury Racing New Design CNC SSM Props
- Edelbrock SuperVictor Intake 10.2 deck
- Who was selling a set of CMI's with 1 bad header????
- Optima billet battery boxes -4
- New Adjustable water pickups Thru Hull &Quick didconnect Engine Flush Kits complete
- Pro Charger AW 504 Intercooler Brand New
- Cleaning out the cabinet
- Big Block B&M supercharger
- Myco 16" 5 Spoke 6 Lug Aluminum Wheels
- 2 closed cooling systems $1000.
- 2 588 ci zul 900's
- two steel trailers
- Its drive with -2 sportmaster lower
- Bravo 1 26P Lab Finish Cupped Prop
- Bravo HP Gimbal bellhousing
- PPI highback bucket seats brand new!
- Gen VI 502 (509) Shortblock For Sale
- Imco powerflow manifolds 2 sets
- parts for sale or trade
- two keith eickert 850hp blower motors
- scarab 30 panther part out
- 525 efi 220 hours freshwater
- 26P Bravo one RH 4 blade for sale
- XR Hering props
- Wilson manifold spacers 1 1/2"
- Bravo 1 Lab 36 P Props Left and Right
- NOT MINE couple of Hardin Marine Sea Strainers on Ebay.
- Blower Shop 5.15" snout
- mercruiser air pump shot gun exhaust
- 2 big block wiring harnesses
- oil lines -12
- pair of mercruiser power shift assemblys
- 2 Livorsi Speedo Gauges 80mph & 100mph
- remote oil filter mounts
- bbc performance parts
- crane gold rockers
- xr lower 1:50 ratio
- Bravo one drives for sale
- Edelbrock Marine carb new in box 1410 750cfm Electric choke.
- rh trs drive
- Trade/swap bbc hp exhaust for sbc exhaust
- Gen 6 502 with merlin heads bm 250 blower baja outlaw hull
- 92 24 baja outlaw hull
- Wtb p5x 24p rh
- Bravo one 26P RH for sale
- Imco sc lowers low hours on refresh sell or trade for -2 shorties
- Imco SC Upper
- holley 1050 carbs have 2
- Mooring snubbers with ropes
- 7 Rims and Tires
- trim pumps set
- eddie marine battery boxes
- 502 390 hp mercruiser long block for sale
- Pair of HP 500s complete with headers.
- Selling my 1974 Formula F-18 as a project boat $3000 obo
- New trailer brake reverse lockout solenoid
- F/S 2 Mercury Racing Cable Grips 846066A 1
- 500 EFI's
- Isotta Aria red
- oil coolers
- Parts for sale
- AnchorShade II (by Taylor-Made) - Teal
- 500efi procharger
- Props
- Couple gauges for trade or sale
- Trade/SWAP 38' Eagle trailer built for Formula 382 Fastech for 38' mono hull trailer
- Props for Sale ! Priced to sell!
- Imco SC Upper with -2 Imco lower (1.5 ratio)
- P-5 15 1/2 x 32
- Project formula 357 on nice eagle trailer
- 380 Kplanes
- Mufflers
- NIB 1:65 gear set for Bravo1 and Bravo1 drive complete 1:32
- Gen 5 - 6 502 Oil pan and oil pump.
- bbc std deck Dart intake 4150 series
- holley 850 4150 marine 80443
- SBC Exhaust
- 6'' KRC power steering pump pulley2
- 850SCI Cam shafts
- 2 different props for sale!!!
- 38' Warlock Cat---CHEAP
- Bravo X Seacore drive for sale
- bolsters and rear seat sun pad
- corsa wiring harness, new
- Lots of Parts (crossovers, IMCO Power Flows, 850 Holley carbs, cams, Brodix intakes
- TWO SETS OF HP 500 CYLINDER HEADS!! and other BBC parts
- 97 Fountain single dash/guages
- holley 1050 doms,have 2
- trs right drive and parts
- Alpha 1 Driveshaft and Propshaft
- Crane Gold Roller Rockers BBC 1.7's
- parting 86 chris craft stinger 31 ft
- Bunch of Misc. Merc stuff.
- 4.5 switchable tips
- 496 risers
- Livorsi speedometer
- Mercury 496 MAG parts
- Hatch Scoop
- Parting out or selling whole 1979 312 Excalibur by Chris Craft 98% Restored
- Marine 45r mechanical fuel pump
- Gm intake manifold for gen v
- 1990 454 magnum flywheel
- 525 heads
- 21p LH Merc cleaver wanted
- WTT Props Maximus and Bravo 1
- 5" inlet Gibson Clamp On Muffler
- World products Merlin marine intake
- MISC Products
- Mercruiser HP500 Manual
- Mercury Marine Silent choice exhaust system for sale
- drive,ex. box. gimble
- 4-4"Teague Marine stainless Steel exhaust tips with internal flappers
- Project 38' with trailer
- 2 Dooley 10 quart oil pans
- Bravo 1 lowers, BBC valve covers, EFI Intake
- 638 tall deck/ Stelling greens
- Volvo SX-a 1.5
- Freebie Morse dual throttle/ shift controls from my Scarab
- 4in clamp on mufflers
- 1090 king demon blower carbs
- Water cross over (Purple, Sterling)
- TRS lower gearcase housings
- Trailer Wheels/Tires
- Bravo One Low LOw Hrs Full Transom Assembly
- RayMarine Chart plotter with GPS
- Sony AM/FM- CD
- Accel dfi fuel injection system
- fresh water cooled for bbc
- 10051107 blocks
- Pro Charger AW 504 Intercooler New. Misc 8 Rib Pulleys
- pie pan
- Bravo captain call
- 2 rebuilt 454's fresh 0 hours
