View Full Version : Swap Shop
- Very clean set of 380 K planes😎
- alpha one 1.32-1 gears for bbc or built small block
- 2 tall pedastal chairs
- K planes
- Brand new merc steering actuator
- 2 TRS back cap steering brackets alumium
- chevy mallory dist YL624AV have two
- chevy velvit drive bellhousing
- Imco cases / stainless marine risers
- trs gimbal internal transom plate and rams
- Top Gun Blower Hatch For Sale
- 32' v bottom trailer (tri-ax)
- Cometic 502 head gaskets
- tall block msd parts
- 489 stroker
- 454 stroker complete motor and drive setup
- Eddie Marine Exhaust
- Selling 2 hp gimbal assemblies
- 17.25 x 25 rolla 4 blade 19 spline
- FS: Drew Marine Shotgun Exhaust Silencers 4" Polished SS $200 shipped
- Canton BBC MK4 oil pan w/pump,pickup and windage tray
- headers
- Mercruiser thunderbolt IV Ignition Module V-6 14 Brand new
- Mercruiser thunderbolt IV Ignition Module V-8 24 Brand new
- Brand new corsa exhaust diverter valve wiring harness
- Bravo 1 34 p rh
- Bravo 1s 32 pitch
- exhaust tips
- 10' Nautica RIB
- Cleaning Out The Garage
- Aeromotive Regulator Fuel Injection
- BB engine parts
- Garmin GPSMAP 421 color gps
- 23Pitch mercury mirage plus RH&LH
- L29 truck fuel injection. any interest?
- 33 Outlaw for sale
- For Rent - 45' x 25' slip, St Joe Isle Yacht Club
- Fresh Mercruiser 502
- CP Performance Oil Cooler and mounts NEW
- Mirage 25p prop sell or trade
- BBC Rectangle port heads
- HOLLEY 12-890 HP high flow electric fuel pump NEW
- Aluminum Dual Axle Boat Trailer for 26 to 28ft boat - $2000
- Complete twin TRS + twin 72c green tag BW +trim+housing+gimbal+hoses+everything $2000
- 2'' Bravo Spacer
- Misc BBC 502 Parts
- vessel veiw 4 "race edition"
- Corsa quick quiet diverters
- Set of bravo 1 4blade props 26p
- Gil exhaust risers.
- Mocal oil thermostat
- Hydromotive qiv 22p rh
- cleaning out the shop bunch of parts +
- super boat y2k cockpit carpit....red
- 2- #6 Driveline Gimbals with inner transom plate $18,000 OBO
- #6 1" spacers no studs $250.00 each Firm
- FEL-PRO Head Gaskets 1017-2
- BEST DEAL 600SC Mercruiser engine $8000 SHIPPED!!!!
- Mercury Racing 525 EFI With Less Than 10 Hours For Sale
- FS: Complete MSD Ignitions and Dual Stage Water pumps
- Prop and header inserts
- Holley EFI Intake (9901 209)
- 4" ID Exhaust tips with external rubber flappers...
- Full Hydraulic Steering for Twins
- Bravo Lower 1:50
- Imco bravo prop shaft 1"
- Big block water pump.
- Bravo Prop Shafts
- Bravo 28 left & right $600
- WTB: Nor-Tech 3900v carpet
- Old school bolster seats
- Cleats, LED trailer lights and pair of props
- CMI 454/502 E Top headers
- gaffrig big gun mufflers
- Gaffrig-Fountain tachometers (2) white
- Complete Dash, with controls, steering wheel, and switch panel
- B-Max upper gear set
- XR Gear Set
- Trim & Tab Switches w/ Panel
- Latham bolts
- Crank Rods Pistons Oil Pans etc...
- (2) 525 EFI's For Sale Complete Drop ins With Exhaust
- Crane ignition
- Bravo 28 left and right
- Port Side Lightning Header with O2 bung
- RH/LH BRAVO 1 22p props $525.00 shipped firm!
- Crossovers for sale. BBC 2 sets
- Closed Cooling
- New thunderbolt modules
- Alpha SS on Ebay
- bbc motors
- gil risers
- Shift / Throttle controls for single engine, like new also a fiberglass shifter pod
- 22 Velocity no power train
- 525sc lower pulley
- Stainless marine risers
- CMI 454/502 E top headers
- 26L Hydromotive and 24L labbed bravo one
- teague platinum bravo shaft
- aronow books
- BBC Complete Blower Setup
- Lightning Headers $1200
- Fireboy 1301 #15CG Halon System, New
- IMCO Dual TRS Drive Plates, IMCO Filter, Silencer Exhaust Tips w/ Elect Actuators
- Fresh 516CID Big Block Chevy, 625hp/650tq, Accessories, $9k OBO
- Bolster seat backs
- BBC Valve Covers $75
- 1987 Target trailer
- (2) 575SCi Blowers - Including spare pullies, intakes and a set of super chillers
- Stainless marine manifolds (4) ttl w/ risers, etc.
- Hatch scoop
- Stainless Marine and Gill Exhaust for sale
- Mercury Gil Exhaust Manifolds with Tails
- Merc 4 blade 19 spline
- Pair of Blower Shop 250's Full Kit's
- 2 sets cmi e tops fresh water
- norcold ac dc rerigerators
- bomar hatches from formula
- gen 5 502 block crank pistons
- Stainless Marine Pipes
- 31p RH Lab Finished Bravo 1 prop
- Merlin cast iron heads 320 cc
- EFI 500 parts gen iv parts
- bbc gen 5 oil pans
- 502 Parts
- Titan Surge Brake Actuator
- Bbc 598 cu in 1200 hp
- Mercury Racing SSM#6 4-Blade Props - 2 sets. 16-1/2 X 29's and 17 X 31's.
- Bravo one 34 pitch props
- (2) complete closed cooling. NEW
- 2-502 rotating assemblies
- BBC Intake
- Pair of Imco drive showers
- Bravo one outer gimble new
- Pair 280 k planes
- 280 trim tabs and 3 step under ladder
- 540 tall decks
- Hp 500 sea pump set up
- Gen 5-6 sea pump setup
- Bravo couplers and bells
- lifeline comp vest
- fuel line for 502 mag
- Head mount remote oil filter bracket
- (2) sets of Bravo I - 4 Blade props 28p lab and 32p stock - Barely Used, Excellent!
- Pair of Bbc gen iv deep sump oil pans w pumps/pickups/baffles/dipstick
- 4 bravo xr prop hubs
- Bravo 1 32p LH and RH Lab By BBlades
- Xr parts
- 2005 Alum. South Florida Triple Axle Trailer - 30-34'Adjustable Bunks - with HD GATE!
- Labbed 28 RH 4 Blade Cutting Edge 1 test only
- 1978 bbc 049 heads 2 sets.
- Bravo driveshaft ext housing assemb. for staggered
- Want to trade Fresh 525/XR's for low hour 496/X's
- (2) Bravo Trim Pumps, (2) Bravo Couplers, (2) Bravo Bellhousings, (2)Shifter Brackets
- SBC Crossover system
- IMCO SC lowers
- Holley carb 8AN fuel log
- BBC top mount starter
- Clever 23p props L&R
- 1/2 mercury #6 spacers
- FS Stock Merc Style Exhaust Risers
- Billet Aluminum Bolster legs!
- mercruiser 1.32 - 1 gear set for alpha one for 454 engine
- cmi header 525 triple engine
- 28 skater race hatch
- Mercruiser Scan Tool
- Marine Machine Hydraulic Steering Dual Bravo set up.
- 2) 525 EFI internally balanced Rotating assembles.
- Brand new Kryptonite trans
- 565 cu.in. 800HP pump gas
- 280 K planes
- 4.25" Stroke Scat BBC Forged Crankshaft
- 25 P mirage plus
- Stelllings for Bravo - Siking deal
- 502/509 mag mpi engines
- 34 Scarab Raider For Sale
- Mayfair External Hydraulic Steering
- 23p stainless props
- imco 3 valve fuel valve
- 25 PowerPlay Rigged Hull on Trailer - No Motor/No Drive/No Steering
- FS: BRAND NEW Garmin AIS-600 BlackBox
- garage clean out, good stuff
- BB crossover system
- bravo hp couplers
- Mercruiser 496 HO Engine Cover
- Bravo Transom assembly complete bell housing back
- #6 1.62 gear sets
- 21P Mirage RH
- Complete Alpha one drive and transom assembly
- 1998 5000LB Tenessee twin axle boat trailer
- 454 blocks
- HP 500 FUEL Injection
- Hp. intake carb air cleaner
- 2 closed cooling kits bbc
- Cast stainless crossovers
- Trs gimbals
- Pair 72c trans with trs plug in tail
- 088 Heads- 24 hours of total use. $750
- Mercury Cleaver, 3 and 4 blades
- Volvo Penta Transom Shield New
- Pair of 420's, TRS's and Trannys For Sale
- Marine Machine billet fuel filter heads
- Dual cooler bellhousings
- 2 144 B&M superchargers
- 2 Holley 800 $550 plus shipping
- 5L whipples
- BBC Chome procomp valve covers (2 sets)
- # 6 drives
- Fresh L29 Heads (casting 279)
- TRS drives, port and starboard,Merc 11 trans, Transom plates etc
- Complete Imco steering system
- Dash Panels and Dummy Lights 1989 Baja 280 Sport
- 1993 Scarab Aluminum Dash Panels
- 2 Bravo CMI headers and tails with the ride up for grabs... steal of a deal
- B&M Chillers up for grabs!!!
- Pair bravo 1s with Imco lowers
- TST Technologies Tire monitoring System
- 525 Headers and tails
- Latham Bravo Mount
- Cigarette racing team black leather jacket
- Two aluminum intakes off Merc 440hp/454 Cyclones
- Carrera SS9M/ Cobalt Condurre 300 no power,steering,drives or trilaer $1000
- 280 K-Planes
- 2 Z Drives (Directs power down or to the side)
- Standard Bravo I upper
- FS: Merc 600-700 SCI 3-3/8 Upper supercharger pulley
- 2- thunderbolt 4 ignitions v6-14 modules
- 5.7 260hp Rochester Carb
- kiekhaefer k-planes
- imco prop shaft teague platinum vertical shaft
- BBC valve covers
- bennett 16x12 sport tabs
- gaffrig silent choice exhaust tips
- 502 mpi gen 6
- Stellings for Bravo with tails one set
- 2 MERCURY BRAVO ONE ZR PROPELLERS - $500 (corona ca) CRAIGSLIST
- Latham tie bar
- Stainless marine heads up indicators
- Mercury Gen V Sea Water Pump w/ Mech Fuel Pump and extras
- Trick Flow Chromoly Pushrod Set - 8.7 x .080/7.65 x .080 - 3/8"
- Crane Cams Valve Springs Dual - #96883-16 - 22 Hours
- Callies Dragon Slayer Crank BBC - 22 hours
- Comp Cams Hyd Roller GT Performance Grind - 3150B/3151B HR114.0
- 32' boat full cover and bblades props for sale
- complete dash out of 419 gaffrig gauges gps speedo
- 2014 Aluminum Boat Trailer. VBT-7900
- 2 sets 4.500 je pistons 509
- F/S or WTT: New Arneson ASD7 bravo conversions
- single plane high rise peanut port intake carb or mpi
- 280 k planes
