View Full Version : Swap Shop
- Bravo inner transome plates
- Random; Flame Arrestor, Hatch lift, Bellows, Thunderbolt V8-24 Module
- Set of BBC Retrofit Hydraulic Roller Lifters PBM
- Crane 133941 Cam and Lifters
- Scorpion Endurance rockers
- Stainless Marine gen 2 with long bravo tails
- Imco wing plates
- Q-Jet Carbs
- HD Damper Plates
- bravo one prop
- Remote Throttle Trim Switch Wanted
- BBC Valve springs
- Bravo 1 props 24s RH/LH
- 2 stainless teague sea strainer 300 plus shipping
- Red radar arch fiberglass. Chris craft stinger wing 500
- Feeler: Morel 4603
- (3) Sets of Crane Gold 1.7 Rockers
- 2 Bravo Gimbles, and other drive parts. Freshwater- Low Hours
- Crane Gold Roller Rockers
- HD Torque Plates
- CMI E TOP bravo style tail pipes
- Bbc Top Mount Starters
- Bennett Trim Tab Pump
- Maximus 15 5/8 x 28 RH SS 5-Blade Lab Finish
- 30P RH Maximus Prop
- 750 CFM Edelbrock 1410 Performer Series Marine Carburetor - (2) available
- 496 ho
- IMCO SC -3 DRIVES (2) Complete
- P5x 25p rh for sale
- Misc BBC 454 parts - heads, intake, Thunderbolt 4 dist complete, valve covers etc.
- Gen VI 502 parts and accessories
- Two Sets Gil Manifolds and Risers
- #6 Upper Gear Sets
- Boost power alexiz-b2twin-port-efi-custom-marine-superchargers
- merc 496/ 385 hp take out
- Hardin Marine - Hydraulic steering thru-hull fittings
- Hydraulic Steering - Inside kit
- Bravo Engine Bellhousing
- GIL Marine battery box - Top only
- Latham Marine Hydraulic Steering Wingplate
- NEW 3.3lt quad whipple set, MOAC intercooler, injectors,
- 24p R Bravo 1 prop with 1" shaft $400 shipped
- Bds 1071, Teague super chiller, complete take off my 540. Includes everything
- Group 24 battery box
- 454 /502 efi intake and injectors, fuel coolers with fuel pump bypass
- Re-built Marine Machine Rams $750
- CMI Big Tube Headers
- 4 Blade speedmaster SSM 32x16.25 props for sale, trade or buy 5 blades 30,31,32 pitch
- Want to trade short sportmaster lower for std.
- ISO Mercruiser 502 MPI Intake
- misc merc bbc parts
- Sale or Trade new Bravo One XR Drive
- 2) Bravo 1.36 outdrives good condition. One has LWP $1300/$1100 respectively
- Brand new 565 stroker 810 hp!
- Vortech v4 j-trim kit almost new
- Zodiac ZOOM
- 2/1'' 50' air hose and reel, new
- Gil manifolds and dry TRS risers
- 2 Latham Tie Bar Brackets For #6 Drives
- B&M Holley 250 Blower & Superchiller Complete package
- M3 sc procharger
- cmi split top
- billet fender holders
- MSD 6M-2L Marine Box
- Twin set of Gaffrig gauges with bezels
- CMI Mufflers 4" Clamp on Sound elimination series
- lh sportmaster 1.87 small shaft 20" all new except case
- Lh cle gear case assembley 1:87 gears
- Bravo 1 Sweptback uppers, 42 hours- Excellent condition.
- Formula 400Ss Cockpit carpeting
- Mercruiser Bravo HD Trim Rams
- Imco SCX with a Merc racing Wilson lower
- 2 set(4) of 4" Gibson mufflers.
- Gaffrig white contols Twins w/Trim
- Eddie Marine k plane mechanical indicators
- Myco Aluminum bunk trailer
- 4" shotgun mufflers
- BDS 10-71 Blower and chillers EFI
- TRS Misc bell housing plate oil coolers, gaskets, covers etc
- Crane Cams 168741 and MEFI 4 ECM
- 454 BBC Mercruiser 1978 Hawaiian
- 468 B&M 420 Gen IV
- Bravo XR Sportmaster ITS 1:35 short
- Hp 500 engine wiring harness, ignition modules and spark control modules
- 4.5 exhaust tips
- BBC Callies compstar 4.25" crank
- Bravo Sport Master Splash Plate- Stainless New
- 2 complete b&m 250 setups, low hour
- Pair of hydromotive p5 31p lh/rh
- Heat exchanger
- 540 Tall Deck Merinl III motors fresh
- labbed 27 pitch 3 blade mirage prop right hand
- F/S: Mercruiser 5.0LX 1994 model year used engine
- mercruiser 502 parts
- Vessel View / Race View
- Maximas Props LH & RH 15.5 X 34 labbed to 36 by Bblades
- Bill Mitchel Blower Motors
- Procharger M1 for BBC, Big Red blow off valve, C&S Carb, Competion bonnet
- Platform
- Hardin alumuim oil pans, meeling billet oil pumps.1 matching pair
- Set of Bravo one 32's
- Gil Manifolds & Risers call or text only 860-922-9228
- Trade SCX for SCX-4
- Boat cleats
- 2005 Mercury 250 efi/300x
- BRAVO ITS TRANSOM ASSEMBLY- Fresh Rebuild
- 500 Bulldog parts
- New Dart Pro 1 - 345's
- Mercruiser XR upper
- 2 Pair of Aquatronics 6 1/2" speakers NEW Cheap
- Bbc tall deck profiler sniper intake $300.00
- 2000 Yamaha c115 outboard 25in shaft
- New cmi bravo tails $250.00 obo
- CMI @pc TUBE TOPS with TAILS 2 PAIR
- Parting out 1984 sutphen
- Marine Machine Full Hydraulic steering
- CMI E Tops
- IMCO SC Upper Housing
- Latham Bravo Cap
- Brand new procharger m1sc kit complete
- Pair of 2008 700sci engines complete
- 26P Maximus Props
- 454 mag gen v stock exhaust
- Silent Thunder Swim Platform
- 280 k planes
- Trs transom assembly's
- Flame arrester's
- Trs drives nice and tight
- 25p 3 blade props
- Huber 1300's
- Huber 1200 plug in trans, 4" tips, bravo bell housings, couplers
- pair of 19 spline 28p 3 blades
- XR Vertical Shafts
- IMCO SC -0 lowers (PAIR)
- SBC cross over system
- XR spanner wrench
- 1" drive spacer
- Valve covers - Merc 500HP blue factory
- Viper Diablo (trade for drives)
- K Plane Actuators
- Complete Twin Kaama Drive Set for sale, Donzi Z33
- KAAMA Parts
- Second Effort/Arneson Surface Drives
- 42 Legacy Swim Platform
- Update to my parts ad SSM Parts
- Auto Meter 100lb Fuel Pressure gauge
- Gaffrig 6k tach
- Bravo XR tools for sale
- 16.5X31P Big shaft props
- 2 #6 1.15 ratio Gear Sets
- Hydromotive 4 blade 29p props left and Right
- Cleaning out the garage. 575sci parts, props, flywheel, bellhousing etc.
- Performance PARTS I AM NOT A DEALER PLEASE DO NOT DELETE MY AD
- Maximus prop 30p RH labbed
- Bravo Gimble ring & bellhousing
- Sutphen 33 comp hull
- 525 headers
- 2 Bravo One Drives Complete $1750 ea.
- Latham External Steering
- Stainless Marine Gen3 $2600
- 1999 Donzi 28 ZX Red Snap in Carpet
- Dana Marine S pipes Polished Stainless
- 33 Powerplay Sport Deck hull and trailer
- Looking for rec ports (trade anyone)?
- Imco scx upper & lower,imco gimbal,imco ext box3'' up and ext shaft
- Merlin heads and cams
- 598ci 1300hp with 5.0 whipple
- new holley 600 cfm marine carb.
- BBC parts
- garage clean out
- Bennet Sport Tabs
- Mercruiser XR UPPER
- 25 P Mirage Non Plus LH/RH
- Vessel VIew 4 & 7
- Imco sc advantage. Basically an xr
- 72c driveline velvet drive transmissi9n (new rebuilt with warranty ) $500
- Pair of trs 72c borg warner velvet drive 1:1 transmissions $600
- Pair of speedmaster 3 drives $1500
- Nice pair of trs gimbles $800 for both
- Mirage 19P prop
- 2 Mark IV 450 HP. 1, Gen 5 450 HP
- corsa silent choice, quick and quiet
- Hatch Actuator
- Marine Generator 8 KW Must GO
- IMCO SC Lower -0
- BRODIX BB3 XTRA O 365cc Runners! Big Block Chevy
- Trade 10" Latham Rams for 8" Latham Rams
- K plane hoses
- 1" drive spacers
- Bravo 1x upper gear set
- MaxBrake brake controller
- garage clean out/moving sale, good stuff at need to sell prices
- Patterson and Other Misc. Headers, Tailpipes, Y Pipes, Manifold, Flywheel
- new mercruiser s-pipes for thru hull exh, under swim plateform
- 2000 Mercury Optimax 200
- Ilmor 725s and Imco scx drives
- Eddie Marine Battery Tray
- pair of maximus 26P props
- Lee inter cooler w/ Hardin marine micron water filer
- Mefi 4 ecm
- Daytona crash boxes
- Kiekhaefer 600 twin ram K Planes
- used bravo 1 1.5 ratio gears
- trim/trailer sending units/ quick silver
- Polished Gil Clamp on switchable mufflers
- pair of #3 drives, gimbles , inner transom plates $3500
- Bravo 1.5 Upper
- Mercury Bravo I One Propellers LH&RH SET 15-1/4 X 24 SS 4 Blade
- Procharger Carb boxes.
- 4 Blade Props #6, 3A props
- cmi rig tube exhaust
- Parts clean out of garage...has to go
- BBC Parts
- 3 blade cleavers
- 4 Blade cleavers, polished for SSM
- Blower idler bracket and pulley
- Billet crank pulleys
- Speedmaster # 3 outdrives , gimbles, and inner transom (sell or trade for bravos)
- Speedmaster # 3 outdrive , gimbles, and inner transom (sell or trade for bravos)
- 2015 300xs offshore clamp and 20 inch exhaust housing , new zero hours
- Eliminator daytona 22 hull for sale!! Selling everything!!
- misc parts
- Pair Bravo 1 28p Props (LH & RH) Flawless Condition
- 2 sets of Kodiak bbc manifolds with elbows
- 2005 Mercury 250EFI/300X Outboard
- 34" Bravo 1 props (no diffuser)
- 1993 38 Scarab
- 45ft aluminum I Beam trailer 2010 model
- 27p lh Mirage Plus $350 shipped
- Gen VI 7.4 roller cam long block
- 496 Mag
- EMI SS Silent Choice risers and Corsa captains call diverters
- 2 Borg Warner TRS 71C Transmissions
- Gaffrig Performance Series Muffler 4.5 I.D. Tail Pipe Stainless, Offshore Scarab
- 25' Go-fast sport deck
- Aeromotive Fuel System + Imco Fuel Switch
- formula parts
- Drew marine shotgun mufflers 4.5"
- IMCO electric hydraulic steering pump
- 500 efi complete intake w/injectors
- Latham steering wing plates all styles
- 454 mercruiser carb webber
- 2012 mercruiser alpha one gen 2 upper 1.81-1 gears
- Eliminator Daytona 36ft 2004 Hull PRICED TO SELL
- KPM super strainers
- Mercury 4 blade cleaver damaged
- Best deal on Mercury 4 blade cleavers
- Hydromotive P5 32" props. Both L & R (TRADE?)
- Imco sc advantage upper xr
- Mercuiser 420HP parts for sale
