View Full Version : Swap Shop
- cat for sale without engine/drive
- GIL HP 500 risers
- Baja and Formula windshields... OHIO
- IAC Valve - Brand New - $20 Shipped
- Pair inline mufflers / baffles; pairexhaust tips with internal and external flappers
- SCX Spacers - 1/2", 1" & 2"
- trade mirage plus 23p rh for a lh
- fresh set of big block chevy 088 heads
- Trs drive and tranny
- Few items..
- Mercruiser Flywheel Bellhousing
- EMI Thunder manifolds with silent choice SS risers
- Pair of 3.18 dia. Whipple Supercharger pulleys
- With a HEAVY heart, I have to ask......Formula 357 SR-1 sale.......
- Pair Mirage Plus 29p
- 280 Profile cat power options available
- 2004 496 Mercruiser stock exhaust manifold's with risers
- FS: 34p Bravo 1 4-blade props Excellent condition. must go!
- 38 flat deck project forsale or trade
- 496 manifolds
- New, 34 pitch Hering 5 blade props,
- Triple Axle Trailer for 353 Formula Fastech, Heavy Duty, Alum Wheels , $4800
- Bravo one 28p L/R SET perfect shap
- hardin big block headers
- CMI 525EFI Gen X Headers
- Pair of 25 Mirages solid hub... (Not the plus!) but cup added....
- 26P Bravo One prop solid hub RH great shape! $450 plus ride!
- Two 468's with blowers
- 25P Mirage Plus Labbed Props
- complete 496 engine low hrs
- MSD Soft Touch 8728 Rev Limiters
- Gil tubular motormounts
- Cutting Edge 22P 5 blade
- Hydromotive 28p l/r labbed
- hydromotive 27p props l/r labbed
- PPI Highback bucket seats NEW!
- Mercury single engine solid front mount plate
- Charles 40 amp 3 bank battery charger $200
- Complete Thunderbolt 4 ign. w/v-6 module, msd coil, taylor wires $250
- Stelling headers fresh water , tested, nice set. $1000
- Hydromotive P5X
- Merc TRS Lab Cleaver 23p
- Imco/Fastglass SBC/BBC Risers
- 385ci SBC Engine FS
- 600sci Computers (pair) only 80 hours....
- 38 Cigarette Top Gun Full Cover, 1200
- Bravo 1 Drive (Locked Up) $250 OBO
- Merc Racing 575 SCI
- HP 500 valve covers
- Left and Rt TRS drives.
- Power SS Hatch Pistons (2)
- Hatch actuator 24" throw
- Cleaning Out The Boat Shed
- Brand New Small Box anchor w/SS Danik Hook & 100' anchor line
- 353 cockpit carpey
- Stelling big tube headers / pfm upgraded turbo setup for sale or trade
- Borg warner 72,
- Hydromotive 5 Blade props
- 2 GM Saginaw Power Steering Banjo Fitting
- 2 Sets of Shift and Ignition Brackets for BBC Gil Exhaust
- 525 sc
- Pair 34's
- Mercruiser alpha 1 gen 2 outer transom assembly
- Gaffrig gauges, bbc engine stands, IAC, water pump
- 454 long block and other parts.
- Lighting headers
- 21' Hammond Challenger FS
- SBC GLM Manifolds/Hardin SS Risers
- Garmin GPS Model 440
- 29 Pitch LH & RH Props
- two 502 offshore motor mounts
- Offshore motor mounts
- Keith Eickert 1000HP BB Engine
- Miss Budweiser Unlimited Hyrdroplane
- Baja 280 force for sale
- exhaust 496
- Package deal: BBC Flame arrestor, Dom 750 Carb, fuel line, and Dart Intake LIKE NEW
- Dual Engine controls - black Kiekhaefer
- 39 Chris Craft Scoripion WITH staggerds TRS boat
- Kiekhaefer 280s K-Planes / Trim Tabs with Pumps
- 28 signature OB parts or whole.
- Livorsi gauges
- Speedo Pitot Assy. - Brand New
- Mirage 25P Very Nice Shape Cheap
- Gil manifolds, 2 pair
- Mefiburn
- Merc Racing ITS gimbals (pair) & matching XR ITS Bravo Sportmaster drives
- Trying to trade a set of 34p stock Bravo's for 33p Bravo's
- trs gil tailpipes.
- eddie marine manifolds
- RH & LH 34P Bravo 1 props
- Heads and tabs
- Merlin BBC Tall deck intake manifold 4150 carb new in box, brass inserts $350obo!
- Imco Risers
- NEW: 12" billet grab handle, 2 aircraft style fuel caps, fuel bezel, trim pump cap
- seats
- Mirage 19p 3 Blade Props
- 2 Mercury SS 23 p RH Props
- 496 Mag ECU - Mercury 555
- Hydro QIV Labbed 22p RH
- gen v/vi cast iron 454 502 heads
- Stock 454 Magnum bits & pieces
- Bravo Trim Cylinders
- FS: NEW Mercruiser Bravo/Alpha OneTilt/Trim Senders 805320A03
- Mirage plus 23p
- WPM Racing steering
- 38 top gun side rails free free
- Brownie's Third Lung Rescue Diver's HELO System
- Purple Livorsi Oil Temp Gauge
- 23P Mirage Plus prop RH
- 520 BBC supercharged engine
- bravo 1 complete gimbal
- Floor mount Fender Holder - Candy Blue
- 240 k planes extended to 31"
- Littlefield 8-71 blower with 850 blower carbs. Excellent shape
- 280 k planes
- #3 Drive small shaft 1.3 Ratio right hand drive
- Merc 502 flywheel bravo bellhousing and coupler
- Stelling "Greens"fresh water,with tail pipes
- Lifeline Jacket
- Canton oil pan, oil pump and correct pickup, full length louvered tray and mtg. studs
- Dana 02 sensor spacers
- 27p Hydromotive Prop
- 2 offshore motor mounts Bbc
- 2 sets of gil manifolds and bravo risers
- bravo one upper 1.65 -1
- Four Gil wet risers with weled on mufflers for trs
- Littlefield Supercharger snout
- Dash panel with harness
- Baja 280 sport partout
- Cerwin Vega 12" Sub
- Coan 2 speed driveline "pair"
- Bravo 2 imput shaft
- New Dana Marine billet trim tab switches/panel
- F/S Mark IV 454 Cast Aluminum Oil pan.
- Mercury 420HP finned aluminum valve covers
- Hardin Marine 420HP Big Block Rectangular Port Marine Heads
- Original Mercruiser 260HP small block flame arrestor with cover
- Mercruiser Big Block aluminum intakes
- Holley 750 Marine Carb
- Silent Choice diverters,elbows, and Y pipes
- Mercruiser Big block distributors
- IMCO SCX-4 Spacer
- 23 p mirage rh
- Parts for Sale
- Two remote oil drain fittings/ 1 hose
- 28 Bravo 1 Props Left and Right
- Hatch for a 311 Formuls 1992
- Gil Risers
- 2 Whipple "Moac" intercoolers
- 1979 Chris Craft Excalibur hull 31 1/2 ft with tri axle trailer new interior
- 2 New thru hull flush kits -quick disconnect
- New Adjustable water pick ups
- Air filters
- Latham Marine end cap
- Two pair (4) slash cut tails
- Drew Marine Shotgun Mufflers
- Bravo II Prop - 19 1/2 " x 21 pitch - RH - Al.
- Bravo I outdrive 1.5
- HERING PROPS 5 Blade Bravo Style 17.5 X 37 Set.
- Bravo II Props - 18 1/4" x 19 Pitch Matched pair (L&R) Al.
- Sell or trade 23p rev 4 props
- Corsa Inline Mufflers
- Procharger setup Big block Looking to go back to stock.
- striping out cigarette
- Parting out 30" Velocity
- 32 foot canvas boat cover
- Stelling Headers "GREENS" fresh water
- 502mpi oem manifolds and risers, great shape $400
- Offshore Motor Mounts - front & rear
- Merc 21pitch tempest plus props
- pair of b&m blowers
- 280 K Planes
- 3 blae racing prop for arneson drive
- Formula F-18 project boat
- Checking interest: 502 long block, fresh but needs work....
- 3 Teagues 900EFIs for Sale with #6 Drives/Trans (400 hours)
- 2 bravo xr lowers teague platinum shafts 50hrs on rebuild
- MEFIBURN standard edtion
- BBC Bravo Drive Project
- 330hp 454, what's it worth?
- Moniter 4000 same setup a a mercruiser DDT
- Brand New Diamond 4.560 pistons
- Livorsi Oil temp gauge & Gaffrig fuel level
- mercury propellers
- Pair of 700 HP Blower Motors
- Manual Shift Bracket for Merc II Trans
- rocker arms
- 97 Wellcraft 38" Scarab
- WTT Whipple side mount crank pulley
- Cmi e-top headers
- 502 509 block
- 502 509 575 hp engine must sell
- Set of stock 32 Merc 4 blade Bravo ones.
- Hydromotive P5x 28 Pair
- cams/ water bybass kits
- ARP head bolts kits ,bbc
- 4" exhaust/muffler tips
- angle gauge bezels
- pioneer head unit w ipod free
- Hydromotive LH props 25 and 28
- Mercury 1500XS with Harness, Controls, Power Trim/w Pump, SS propeller
- 57-865615-010 Belt BRAND NEW
- 36 RH Bravo One Prop
- Gen VI Roller Lifters Factory GM
- Factory 502 450hp 502 mag Cam
- Mercury Racing 28P RH Labbed Prop - Basically new
- forsale misc parts
- 502 block gen 6
- Pair of 32P Bravo 1 props.......
- Custom inlaid carpet for Donzi 22ZX from Custom Marine Carpets
- Two Merc 420Hp 454's 100% Complete with Gil Exhaust
- exhaust for big block bravo setup
- Stelling Headers, Greens,fresh water,
- 23 P Mirage's lh/rh just redone...
- Props, Props, and more Props!
- Bravo 1 32 pitch four blade non labbed props
- 1998 Baja outlaw 24 SE and trailer (parts or rebuild)
- Brand new Fountain Stainless Sea Strainers
- New Auto Tec Forged Pistons
- bravo 3 props worked by BBLADES 26p
- 1997 22 Scarab no motor/drive on trailer
- hydromotive p5x 30p prop
- BBC Bellhousing - BW/Trans style $100
- Gil Manifolds
- Original Donzi document bag and 1970's sales cards
- 23p rev 4 pair
- Air Dock for sale, Buffalo,
- Volvo penta/ ford 302,drop in
- IMCO SC drives w/-3 lowers
- Tie Bar with saddles!!
- 1990 baja 210es needs motor work
- 24 skater hull
- Parting out 1987 10 meter fountain TRSs tans. Steering. 280 k planes
- TRS Drive with Gimbel Assembly
- CMI Mufflers
- 1990 35ft sonic with 40ft triple axle trailer
- Teague 1450HP quad rotor New motor for sale.
- Labbed 35p bravo 1 props
- Clean mercruiser y pipes
- Hardin strainers
- 42' American High Performance trailer
- some free stuff
- For sale bravo 30 pitch left hand 4 blade stainless steel
- Bronson/Hill bravo drive showers
- Mercury Marine Mirage Plus Props left and right 23 Pitch Like new
- 2 Bravo 1's will sepearte if needed
- Merlin X and HP Holley
- MERCURY RACING 5 BLADE #6 pair,for trade or sale
