View Full Version : Swap Shop
- Weiand Team G Dual Plane Intake
- Edelbrock Performer 2.0 Dual Plane Intake
- 454/502 Mag Carb intake
- Gen 5/6 bigblock and related bravo items
- Kinsler efi belt pump new
- Bbc Imco powdercoated merc blue
- Baja swim platform
- Bravo 1 28 RH labbed finish $650 Best offer
- 25 tempest 3 blade
- SSM Props 19 spline
- Single engine two stick throttle control
- More misc small parts...
- 2 Offshore Race Motor Mounts and Sea Strainer
- Throttle and Shifter/ Rough Cosmetic Condition
- Bravo 1 Outdrives 1.5:1 w/ Heavy Duty 1.25” Propshaft
- Gil Offshore Performance Exhuast w/ Full Length Dry Tailpipes
- IMCO drive shower
- Parts parts and more parts
- Emi thunder exhaust
- New aluminum MERCURY OIL PAN PART # 87758A1
- Hardin dual stage sea pumps . Like NEW
- 29.5 Scarab
- Mercury Racing Pistons (used)
- 1 pair Mercruiser manifolds/ cast stainless risers freshwater only
- 1984 36 carrera step boat
- McLeod Bolster seat
- Bravo one gimbal housing
- Pair of Aluminum 8in Setback Outboard Brackets Jack Plates
- Complete SSM 3 package
- A few odds and ends
- SSM #5 Drives, Ext Boxes,Wing Plates, Tie Rod.
- Twin 525 Efi's /Bravo XR ITS with headers..
- Dual cooler bell housings
- Cupronickel Intercooler Cores (Test Time Only)
- Pair of gil sea strainers
- Stainless Marine Exhaust and sea strainers
- Bravo XR transom assemblies
- Mercury Bravo 1 Propeller Brand New in Box
- Bravo XR upper
- Merc Labbed 34P Bravo One's
- Number 5 drives
- Pair of 540 10/71 Mooneyham motors
- Small arrestor
- Super Starter
- HP 500 arrestor
- Mercruiser pcm555
- Milodon bbc #31556 1-piece gen 5+6 oil pan and pickup
- 2 Mounting Brackets for External Oil Pump & Alternator
- Whipple Supercharger 4.125” 10 Rib Pulley $100
- 34 pitch Bravo I RH labbed by BBlades
- 489 stroker
- 272 Baja Cockpit Cover
- Heavy Duty Racing front motor mount !! Like new !!
- New Console for the Nor Tech 45' sport center console
- 39' Midnight Express Offshore Center Console. Missing motors and drives
- Mercury Racing Double Ram K Planes / Trim Tabs with pumps
- 1 fuel Filter & 1 Flame Arrestor
- Fluid Reservoirs - 2 different Kinds
- Power Steering Pumps - 2 different Kinds
- Set of Arneson ASD #8 Racing Surface Drives with Rams and helm
- Bravo 1 Outdrive with Heavy Duty 1.25” Propshaft and Cartier
- used hydraulic helm
- 4 Bellhousings, 2 Steel Flywheels, 4 Starters, Oil Coolers - Get it all in one lot
- 2 Fluid Reservoir Containers
- 3 stage pump, extra parts and 4 water crossovers.
- 4 Chrome oil coolers with brackets
- 2 Complete Thunderbolt ignitions with Distributors
- Pair of bravo trim pumps
- Pair of LS engines
- Harland Sharp Bbc 7/16 Roller Rockers
- Pair of bravo one transom assemblys
- Pair of holley marine 750 double pumper carbs
- Keith Eickert / Hardin engine mount 1 set
- 92 fountain SC part out
- Motor parts and other whatnots
- Freshwater TRS transom assy
- 4150 Billet Dual Carb Flame Arrestor
- (2) Bravo 1 Drives with Dual water pickup
- 1972 Formula F233
- Raw Water pump with bracket and tensioner pulley with fuel pump provision
- Props-28 pitch
- Hardin Engine room vents 17 5/8". 2 1/2" white
- Hering 5 blade Bravo XR props 30 pitch
- ISO 55-56in Outboard Tie Bar or Trade for 62in Tie bar
- Marine Audio Swap Shop ****
- Mercury racing vintage gauge bezels and switches in dash pod.
- Hp 500 parts
- scarab thunder parts
- Rebuilt Tr outdrive
- Bennett trim switches. Both for $50.00 plus the ride
- Stuff
- CMI stainless split tops
- Dan olsen stringer mount cooler
- TRS Tie Bar 32 1/2" 200.00 shipped
- 16.5x34 L&R 4 Blades
- XR DWP lower
- Bravo lowers
- Mercury top mount starter bellhousings silver powder coat 2
- Holley talldeck efi marine manifold
- Eddie Marine big block Chevy valve covers silver
- Several wind flaps and a windshield for...
- Caliber glove box new white Wayne Earl MFG
- Bravo 1" spacers
- delphi injectors 25176061 ,496 engine
- 2004 496 engine,parts
- Merc 525 hardin marine seawrd manifolds
- 4" Stroke Eagle Crankshaft
- 2 4.5" Eagle Crankshafts
- Hawk/Carolina Racing 468 cube 575's
- Carrera SS9M/Cobalt Condurre 300 no power,steering,drives + triple axle trailer $3000
- Bravo 1 L&R props 34p factory condition.
- Max 32 Pitch
- 1980 carerra SS7M part out
- New imi high torque starter
- Mercruiser 800HP. SC Blower motor with headers
- Yamaha SS prop
- Teague valve covers black
- Ss crossover, thremo housing
- Arneson ASD #12 Surface Drives complete set from Magnum 53'
- 2002 500EFI Ready to Run
- 40' Aluminum triple axle Heavy Duty Trailer Frame!! Unused !!
- 496 Inovation Race motor 580hp with headers.
- NEW LATHAM MARINE 2 stage pump
- MERCURY 525 heads ready to bolt on.
- Oil pans
- New edelbrock aluminum heads
- Fittings and hoses
- 1988 Team Warlock modified V step hull
- 1990 42’ Fountain triple hp 500 bravo one
- universal fuel cooler
- Outboard Steering Wingplates !! Over 50 of them !!
- 32 Baja part out damaged hull
- Hardin ss risers for stock merc exhaust
- Cigarette Pillows
- Garmin GPSmap 182C
- Cmi and stelling headers
- Mercury-Mercruiser 1075 Alternator
- Mercrury Bravo 3 Lover Unit
- Mercury Speedmaster 7 Drive
- Mercury NXT Drive $12,000
- Mercury NXT Transom assembly $8,500
- Mercury NXT Transmission
- 2 new Livorsi gauges, 1 Teague water p/u
- Oil filter head with adapter kit to work w gils
- Pair weiand 174 blower kits complete.
- 502 MPI parts
- Bravo one DWP lower
- Windshield and other parts for sale
- Cheap BBC Parts
- OEM 525SC Input shaft and pulley
- Mercury Gear lube bottles / monitors
- 83 32 Hustler, no power
- Diamond Pistons 4.470
- 36' Cobra Cat Sea Viper. Been sitting 3 years needs work !!
- 50' Cary Offshore Express Yacht !! No motors no drives
- Gil Offshore Performance Exhuast With full length Dry Tail Pipes
- aluminum 496 exhaust manifolds
- 2- Latham Racing steering rams!! Good shape !!
- fuel cooler universal arizona speed marine
- 454-502mpi mefi 1 modded fuel rail complete
- 454-502 mpi mefi 1 1995 1996 adjustable fuel regulator
- Bravo 1 transom assembly and outdrive.
- Mercruiser 1.7" Exhaust Riser for 4.3 V6
- Gps/ vhf lowrance garmin standard
- 1993 26ft Velocity Raceboat Hull and Trailer only
- 1" Bravo Sportmaster Spacers
- BBlades Bravo 1 34P Labbed RH/LH
- Mercury 380 K Plane trim tabs with pumps.
- Power tech props for Bravo one drives 25p 4 blade
- 2- Mach Props . 4 blade Stainless 14-1/2 by 28 Bravo
- 2 pairs of Drew Marine Shotgun Mufflers
- 2 Merc Complete Transom assemblies
- 2- sets Double Ram Mercury K-Plane Trim Tabs
- Radar Arch for 28' Baja. With electronics box great shape
- 2- 17x26 props for Speedmaster #3 drives good shape !!
- 2 Mercury Props 28's fits Arneson ASD 6 and Bravo XR
- 2- Rolla props 4 bladed. 16x22. Arneson and Bravo XR
- 3-1/2 Rolls of 50" Fiberglass Biaxle cloth and 1" coring
- 280 K Plane Plates
- 53' Myco Heavy Duty Catamaran Offshore Race Trailer
- Twin 540ci/600 HP with Bravo XR and ITS gimbles
- HD Mercury Racing trim pump
- Parts
- IMCO SCX lowers 1.5
- Pair of Hering 5 Blades 30 Pitch
- 83 Four Winns Liberator 201
- Big !! Fabio Buzzi TriMax Racing Surface Drives with Rolla props
- Arneson ASD 8 Surface Drive transom wedges 16" drop
- 496 Inovation Race motor 580HP with Exhaust
- Engine/Drive/exhaust package
- Stainless Marine Exh, BBC
- Unused marine Machine K Plane Ram . Only one !
- 2- Stainless Steel Rudders for surface drives
- 32 pitch BBlade 4-Speed
- #6 gears
- 4- Daytona Crashboxes in great shape with driveshafts
- Blower / Suoercharger with Manifold and Holley carb plus more !!
- Merc bravo hub kit....brand new in box ....65
- Y2K superboat front seats..800
- labbed 32 Bravo one for sale ( Gibbs Propeller)
- MEFI 4a ECM and converting harness
- Gear Lube Bottle - NIB
- New Mercury ITS gimbles
- New M6 Drives and Gimbles $70,000
- Triple 480 Yanmars with Zf trans and Arnesson Asd-8 drives
- comp cams push rods 7912-8
- comp camp push rods
- lunati retro hydrolic roller lifters
- New style Bravo drives for sale
- Bravo Sportmaster XR lower unit !! Unused
- Arneson ASD 6 trim ram extensions !! Stainless steel
- Char Lynn Racing steering helm still in the box .
- Campilano Race helm
- 24' bravo , 26' , 28', props
- bravo one for sale fresh water use only
- 509 502 with proline heads 550 hp runs excellent
- big block stainless marine manifold and tailpipes
- IMCO hydraulic steering rams
- IMCO sc case and cap
- 454mpi for sale
- B- max upper gears 1.33/1 ratio unused !!
- Bravo 1 28" counter rotation Props great shape !! For XR drives
- 32' Hustler F2 Factory Race Boat !! Good shape !!
- Unused 86" and 65" Stainless marine tailpipes
- Quad Catamaran Offshore outboard Bracket for 38' to 55' long cats
- Triple outboard Bracket for 2.4 and 2.5 Mercury Outboard's
- 4 Hardin Marine Stainless headers ! 2 sets !!
- 4 Cigarette Saddle fuel tanks for the 38' and 42' Cigarette
- 4-496 Exhaust Risers only one hour on them since new !!
- BBC Cross Over / Pressure Release Valve
- 60" Catamaran Steering Stainless steel Tiebar
- Maximus 24P L and 27P Tempest R
- 1" Balsa wood coring for boat building 3M brand 5-1/2 boxes
- Fiberglass Biaxle cloth. 3-1/2 boxes. 190lb boxs 50" wide
- Motor mounts!! 2 boxes of them .
- 575SCI parts
- Hardin Marine Crossover
- Trs drives and parts
- GIL Triple Engine Exhaust
- 500hp camshaft
- Pair of Gil risers
- 27P mirage props
- 496 ho pcm
- Pcm 555 reduced
- Brodix big block chevy tall deck hvh intake manifold
- Kinsler & Chrower Fuel Injection
- 2 sets of weiand 256 chargers and hardware
- 2 pair Imco 30* risers
- Mercury Labbed 35’s RH/LH Bravo No Diffuser
